Go Back   WorldwideDX Amateur Radio Forums > Forum Friends & Partners > A1 Antennas
Amateur Callsign Lookup
Enter Callsign:
BASE ANTENNAS
  #9
Old 09-03-2011, 07:12 PM
Senior Member
tecnicoloco is on a distinguished road
Default
__________________
Kenwood TS-120S,MC-50 Mic,Yaesu FP-700 PS,Antron 99 W/GP Kit at 20Ft.,4 Elem Sirio Optimized for 27.555 Mhz. RP789 Design at 12 Ft,MFJ 949 Tuner.
  #10
Old 11-10-2011, 04:13 AM
Junior Member
jim/238 is on a distinguished road
Default ant
I run a Maco V5000. It does a very good job. I have run a Imax 2000 & it works good. The V5000 can stand all you can put into it, but it can not stand a direct hit from lighting. jim
  #11
Old 11-10-2011, 07:33 AM
Senior Member
wa4gch is on a distinguished road
Default
Quote:
NO ANTENNA CAN ! Even the ones we use here at the jail
This is my 2 meter one it will take over 500 watts The antenna is about 16 foot and it stands 45 foot to the tip off the street
  #12
Old 11-10-2011, 08:13 AM
BOOTY MONSTER
Guest
Posts: n/a
Default
Quote:
Originally Posted by ray View Post
Who can make me a REAL and i mean REAL GOOD base ANT? 73s. RAY.
i just noticed this is in jays section .........
have you considered a interceptor 10k ? they are pricey but supposed to be very very durable . it should perform as well as any other properly designed 5/8 .
or you can home-brew something yourself that suits your wants and needs .
  #13
Old 11-10-2011, 03:02 PM
Senior Member
Shockwave will become famous soon enough
Default
Commercial broadcast antennas take direct hits on a regular basis. Most of the time no one even notices because they are designed to sink the currents involved directly to ground. Sometimes the transmitter fails, the antenna can have holes punched through it and loss of pressurization. Other times the center pin in the flange connector opens up and you lose the bay.
  #14
Old 11-12-2011, 05:12 AM
Senior Member
Default
Quote:
ALMOST TRUE ......
However even the commercial ones we use here get smoked ........
On 460mhz we use 4 and 8 bay diploes and we do lose them this is why we keep extras in the repeater room .....
  #15
Old 11-20-2011, 09:11 PM
Senior Member
Default
These is a difference between the antennas used for two way radio and the commercial broadcast versions I'm talking about. These antennas are often constructed from heavy wall brass tubing over 3 inches in diameter. It's a little harder to smoke one of these but as I said they still get holes punched through them and the center pins of the 1-5/8 inch EIA connectors can burn right open on some strikes.
  #16
Old 11-22-2011, 03:50 AM
Senior Member
Default
A 3 inch dia antenna at 460 mhz ?
Ours are DP folded dipoles and some 6DB gain ones in fiberglass domes ....
No Comet or Diamond junk no ringo rangers and no MFJ's
We still lose them once and a while
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
legal height for 10/12 meter base antennas ? BOOTY MONSTER Amateur Radio Antennas 19 07-03-2012 10:03 AM
the truth according to Firestik (get a drink and a snack , LOL) BOOTY MONSTER CB Antennas 14 04-20-2011 07:50 PM
Fs: 2 base antenna's radioman24 CB Radio Gear SwapShop 3 01-25-2011 09:39 AM
Safety Standard for CB Base Antennas Master Chief CB Antennas 0 09-04-2007 09:09 AM
Powered by vBulletin®
