I was in the process of questioning the 1/2 wavelength that you were using compared to the center frequency you ended up with, but when I looked back to check something---the length had changed. This is a rewrite!
It is not a problem, but I suggest tuning thru the working feed line is iffy business using either an inline meter or an anlyzer. And, for sure if we don't know what the match is at the feed point the line is likely to show us mixed results unless we are lucky and the tuned 1/2 wave line is cut for the frequency that our antenna is tuned to.
In your case you were likely very close since Steve gave you the numbers, so using the feed line probably did not make a difference. But I still ask, how do we ever know for sure that the line is not affecting what we see. If we see a flat reading at the radio end, that is fine for the radio, but the true match at the antenna still might not be what we think.
Your example of using the 4' jumper to the switch from the meter pretty much confirms that problems can develope in our measurements when using a feed line. I assume what you are suggesting is that you had a flat match at the antenna because the line was a tuned 1/2 wave multiple feed line and showed you on your analyzer that the condition at both ends of the line were the same, meaning a true match. If that were so, then doesn't the rule tell us--that if we have a true match or very close, then the line length does not matter.
BTW, I checked my old notes and I find plenty of my R, X, and SWR readings that are real close to your reading @ 26.372 mHz, R=42, X=14, SWR=2.01, but none of them are anywhere near 2:1 SWR. This might not be a good analysis of what goes on with SWR, but that is what I see.
I just don't have the confidence I once had in my analyzer. Maybe this is would be true for me with all of them when a long feed line is involved.
Did you tell Steve you wanted to tune somewhere around 27.500 - 27.565 somewhere? If not, where and did it make you wonder why you ended up in this area? During the scanning of your frequencies did you ever see a point in the bandwidth range where you saw R=50 ohms?
Good luck,
