Go Back   WorldwideDX Amateur Radio Forums > Amateur Radio Related > Amateur Radio Antennas
Amateur Callsign Lookup
Enter Callsign:
NMO or SO239?
Reply
  #1
Old 08-17-2011, 06:52 PM
Single Sidebander
Turbo T is on a distinguished road
Default NMO or SO239?
On 2 meter/70 centimeter dual band mobile amateur radio antennas that have a coil in the base, do they make any that are SO239 mount? Or are they all NMO mount? I've yet to see an SO239 mount 2 M/70 CM antenna.
Thanks in advance.
__________________
231 from Missouri
  #2
Old 08-17-2011, 07:22 PM
Moleculo has disabled reputation
Default
Yep, they sure do and I have several in use. I have this Comet SBB-5, which is a decent basic antenna and also this Comet CA-2x4SR, which is a really nice broadbanded antenna.
  #3
Old 08-17-2011, 07:33 PM
Single Sidebander
Default
Thanks...would you say the CA-2X4SR is the better antenna?
__________________
231 from Missouri
  #4
Old 08-18-2011, 07:26 AM
Captain Kilowatt's Avatar
Professional Amateur
Captain Kilowatt is on a distinguished road
Default
I also have the Comet CA-2x4SR antenna with the SO-239 mount and will agree it works quite well. I have had it for over 10 years and it has never failed me yet. I really like the fact it is quite broad banded. It easily works the provincial Emergency Measures Organisation's SAR repeaters with their 143/149 MHz split.
__________________
  #5
Old 08-18-2011, 08:13 AM
eagle1911's Avatar
Senior Member
eagle1911 is on a distinguished road
Default
I also have an SBB-5 from Comet.. love it! Great performance, low SWR, strong and solid construction. My favorite thing about the SBB-5 as opposed to many other dual-band mobile antennas is it's subtlety. It's painted flat black from top to bottom, and it's shaped like an oversized (38") old style cellular phone antenna. It's not big and gaudy, but it still performs excellently.
  #6
Old 08-18-2011, 09:44 AM
Single Sidebander
Default
Quote:
Hey what kind of SO239 mount do you have? I'm looking for a roof mount type.
__________________
231 from Missouri
  #7
Old 08-18-2011, 09:58 AM
Default
I'm using this one. Diamond® Antenna ~ K400C Trunk/Hatchback Mount on the rear door of my Ford Escape. I also use the K400-3/8 on the rear door for an HF antenna with a 3/8-24 stud mount.
__________________
  #8
Old 08-18-2011, 12:02 PM
Default
Quote:
I use something like this one: Diamond® Antenna ~ C101 Cable Assembly, although the one I use has different coax.
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
CB Radio Cobra 19DXIV and Larsen NMO 27B darrenster CB Radio Gear SwapShop 0 01-05-2011 04:27 PM
Larsen NMO 27B Frequency Change darrenster Amateur Radio Antennas 8 12-27-2010 04:41 PM
Mobile 2m/440m antenna that fits a SO239 male? Brandon1 Amateur Radio Antennas 11 04-09-2010 04:33 AM
NMO Mount Roof Installation Question wcsd106 Amateur Radio Antennas 9 03-02-2010 08:22 AM
Powered by vBulletin®
