Go Back   WorldwideDX Amateur Radio Forums > Amateur Radio Related > Amateur Radio Antennas
Amateur Callsign Lookup
Enter Callsign:
Picked up what I was told is a Ringo Ranger for 2 meters
Reply
  #1
Old 10-02-2011, 01:50 PM
Single Sidebander
Turbo T is on a distinguished road
Default Picked up what I was told is a Ringo Ranger for 2 meters
I picked this up today for $30. (hope I did good) I was told it's a Ringo Ranger antenna but I don't see any markings on it, other than the coax does say "Cushcraft" which I have read is the maker of Ringo antennas.
I had to add in a 5 ft. TV antenna pole between the main antenna and the vertical ground plane. I found out the connector on the ground plane is jacked up. Some idiot cross threaded the connector on at one point so the threads on the tip are messed up.
Maybe I can score this connector really cheap? Or is it imperative there needs to be a coax connected between the horizontal ground plane and the main portion of the antenna?
Anyways please view the pics and advise. Thanks in advance.
__________________
231 from Missouri
  #2
Old 10-02-2011, 02:07 PM
binrat's Avatar
binrat is on a distinguished road
Default
I was given 2 Ringo Rangers last year. 1 for VHF and 1 for UHF. That looks the UHF 1 that I had. I gave it away to another local who plays with UHF.
Edit: I shall correct myself. Look here, depending on the length it may very well be VHF.
http://www.cushcraftamateur.com/pdffiles/ARX2B.pdf
  #3
Old 10-02-2011, 07:17 PM
Dave_W6DPS is on a distinguished road
Default
That is an ARX-2B. They are a great antenna.
I used one for years, until I replaced it with an ARX-270 dual-band.
Make sure you clean it up as you assenble it, since aluminum does corrode. Use sealing dope on the coax at all three connectors, and plan on redoing these two things every two to three years. With periodic cleaning and resealing this antenna performs very well--almost rivalling a beam with an omni-direction pattren!
__________________
Self appointed expert, and font of occasionally useful information.
  #4
Old 10-02-2011, 08:05 PM
Single Sidebander
Default
Thanks Dave. May I ask, is it imperative to run the ground plane radio on this antenna? One of the radials broke off today.
__________________
231 from Missouri
  #5
Old 10-02-2011, 11:04 PM
Default
Quote:
If you remove the radial ring and coax sectionfrom an ARX-2B, and feed directly to the ring match, you now have an ARX-2. You lose a couple dB, but it is not too bad.
Cushcraft (now part of MFJ) sells replacement parts.
Good luck!
__________________
  #6
Old 10-03-2011, 03:27 AM
Single Sidebander
Default
Cool. I may try that as I'm anxious to get this up to start talking.
The guy I bought it from said it also worked on 70 cm....any truth in that?
__________________
231 from Missouri
  #7
Old 10-08-2011, 07:27 PM
Senior Member
wa4gch is on a distinguished road
Default
ar2 no it is 2 only
  #8
Old 10-08-2011, 07:56 PM
Single Sidebander
Default
Thanks Bruce, good to see you here and not just the truckers forum. Guess the guy lied to me, he said he could run 70 cm with it. I've not tried it nor will I.
__________________
231 from Missouri
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Cushcraft Ringo for 2 meters....? WX2MIG Amateur Radio Antennas 6 01-03-2009 04:57 PM
Powered by vBulletin®
