Go Back   WorldwideDX Amateur Radio Forums > Amateur Radio Related > Amateur Radio Antennas
Amateur Callsign Lookup
Enter Callsign:
OCF Dipole Dimensions
Reply
  #1
Old 10-19-2011, 03:12 PM
Junior Member
tahrens is on a distinguished road
Default OCF Dipole Dimensions
Hi Folks,
I want to put up an OCF Dipole (off center fed). I want to put up the 'long' one that will also do 160.
What are the true dimensions of each leg? I've read 180' on one, and 90' on the other, but was wondering if there is a 'true' dimension.
I'm going to use a 4:1 balun at the feed point.
Thanks,
Tim W5FN
  #2
Old 10-19-2011, 04:10 PM
RatsoW8's Avatar
Supporting Member
RatsoW8 is on a distinguished road
Default
You can build anything but I don't think the OCF will work very well for 160 though.
I used this to build mine but you can plug in ant freq. you need and it works the same.
The formula:
For a dipole antenna cut to 3.6 MHz, take 468 / 3.5MHz and you get 130'. That is the overall length of a standard dipole. Normally you divide that in half to find the center feed point; however, we are feeding this 14% off-center to add 14% to 50% and you get 64% for the longest leg and 36% for the shortest leg.
So, 130' multiplied by .64 (64%) gives the longest leg length of 83.2 feet. the shortest leg length is the remainder, or 46.8 feet. You can double check this by reversing the math, 130' multiplied by .36 (36%) for the shortest leg is still 46.8'.
__________________
Closet Biker, CB'er and snooty Ham!!
20 wpm Extra
  #3
Old 10-20-2011, 06:18 AM
wavrider is on a distinguished road
Default
Ratso is Dead on the dimensions, Same way I built one for a blind ham friend of mine, needed a no tune antenna that required no switches to operate.
I did find I got a better match hanging it from the center of the dipole and left the balun hanging at the feed point, looks like an inverted V feed OC which it is.
Then I built him a fan dipole for 20/40/80 meters works 15 off the 3rd harmonic of the 40 meter leg.
Fan beats the OCF on TX and RX.
  #4
Old 10-20-2011, 07:30 AM
Crotchety Old Bastard
W5LZ is on a distinguished road
Default
There really isn't a 'definite' length, too many variable like height, what's around it, etc. Start with a 1/2 wave length at the desired frequency, feed it at about 33% - 38% from one end, and adjust for best match as you would any antenna. There's no good reason to use that balun, an OCF antenna isn't 'balanced' to start with. The point in feeding the think off center is to get the input impedance closer to what you want, so that '4:1' ratio isn't needed either.
Have fun.
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dual Purpose Ladder Line Dipole wcsd106 Amateur Radio Antennas 9 06-05-2011 10:04 PM
OCF dipole airplane1 Amateur Radio Antennas 24 06-09-2010 01:38 PM
Powered by vBulletin®
