Go Back   WorldwideDX Amateur Radio Forums > Amateur Radio Related > Amateur Radio Antennas
Amateur Callsign Lookup
Enter Callsign:
need info on how to modify a sirio sy27-4 for 10m
Reply
  #9
Old 11-05-2011, 08:28 AM
eacky's Avatar
Junior Member
eacky is on a distinguished road
Default
Thanks to all for the good info i will resize the elements and not bother with the spacing. I dont think the spacing will make to much of a difference, i'am new to ham radio and the internet. Got my ticket last month n' i've been a sw listener for about 15 years so i think i know a wee bit (not much) but its good to have the internet for info from people who know better thank guys. 73
  #10
Old 11-06-2011, 11:42 AM
Robb's Avatar
Yup
Robb is on a distinguished road
Default
Sent to me from Sirio/Italy:
Dear Mr. Xxxxxx:
SY 27-4 is not a tunable antenna and SIRIO ANTENNE doesn't effect
substitutions and doesn't guarantee the correct working of altered products.
However, if you really want to try to change the work freq. of the antenna,
I can give you a method.
To work at 27.555MHz you must to RESCALE all lengths using this formula:
Final_length = (27.2 / 27.555) x Initial_length = 0.9871 x Initial_length
So:
REFLECTOR : New length = 0.9871 x 5740 = 5666 mm
DRIVEN: New length = 0.9871 x 5400 = 5330 mm
1 DIRECTOR: New length = 0.9871 x 5130 = 5064mm
2 DIRECTOR: New length = 0.9871 x 4890 = 4827 mm
Initially, I suggest to not rescale spacing between elements (only for
mechanical
possible problems) and verify the correct electrical working.
After the rescale you must to tune the antenna moving the gamma-match and
using a ros-meter (I can't help you now; the new position is not prevedible)
If the antenna doesn't work well; then you can also try to rescale the spacing
between elements (using the same formula above)
Reflector-driven: New length = 0.9871 x 1570 = 1550 mm
Driven-1 director: New length = 0.9871 x 1020 = 1007 mm
Director 1 - director 2: New length = 0.9871 x 1410 = 1392 mm
Then re-tune the antenna by moving the gamma-match.
I remark that this is only a theoretical method and we don't guarantee the
correct working of antenna.
Best regards,
Ing. Mezzadrelli Lorenzo
Engineer/Sirio
__________________
BASE: Kenwood TS-2000, GAP Titan DX, Diamond X50A, Sirio SY27-4, and IMAX 2000.
MOBILE: Galaxy DX99V w/RF Limited CR-577 mic, Sirio Z-180. Yaesu FT-8800R & Diamond NR-770.
  #11
Old 11-06-2011, 01:14 PM
eacky's Avatar
Junior Member
Default
Thanks Robb much apprecitated man, now i know exactley what to do all the best, cheers.
Reply
Bookmarks
Tags
10m radio, sy27-4
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Review: Battle of the Base Load Mobile CB Antennas Robb CB Antennas 34 10-08-2012 03:08 PM
Sirio SY27-4 Beam Install Robb CB Antennas 11 03-01-2012 11:20 PM
How to modify Vertex VX-230 dag008 Yaesu 2 01-09-2012 12:06 PM
need info on how to modify a sirio sy27-4 for 10m eacky Amateur Radio Antennas 0 11-03-2011 07:36 PM
4 element sirio vs. 4 element maco flat side radioreddz CB Antennas 8 05-15-2010 03:01 PM
Powered by vBulletin®
