12-09-2011, 05:59 PM
 | W9WDX Amateur Radio Club Member | | Join Date: Jun 2010 Location: K
Quote:
Originally Posted by Happy_Hamer Do you listen to the scanner and the ham radio at the same time?
If not, get a dual band antenna like I showed you earlier and put an antenna switch in the vehicle to the radio and scanner and just use the dual band antenna for the scanner | yes i do listen to the scanner and hf at the same time. its why i have 3 antennas. i am curous tho if i wanted to cut the whip how short does it need to be to get the match back...? i have two more extra whips to this trashy tram 2m 5/8 antenna just incase.
__________________ Many people are very Insecure. They need to surround themselves with exclusive Friends to Validate their own self worth. |
