Go Back   WorldwideDX Amateur Radio Forums > Amateur Radio Related > Amateur Radio Antennas
Amateur Callsign Lookup
Enter Callsign:
2m DX
Reply
  #25
Old 02-16-2012, 01:01 PM
Senior Member
avistar23 is on a distinguished road
Default
Ive read the complaints about the wait, he was upfront with me, and im fine with that, he worked with me in areas i needed, and i will gladly support a smaller company with a quality product over a larger cooperation. if i use an amp, i think i will buy a second larcan like i have, for a pre amp, i don't know, none of the mast mount seem to come with relays that can handle over 60 watts, unless you spend 4 to 5 hundred on them.. which is alot for me at the moment for a preamp. and to put up a high power rf relay network up on the tower just for the preamp is a little much. If i find it to be viable and i start making contacts, then yes i would find the investment worthy, but to dump a large chunk of money into untested waters is not my cup of tea so to speak.
if anyone knows a good place online to buy lmr 400 let me know, im running low, im thinking about importing a 500 foot roll if the price is right.
  #26
Old 02-16-2012, 02:49 PM
EDUK8TR's Avatar
EDUK8TR is on a distinguished road
Default
Quote:
I'm using Bury-Flex by DavisRF. Davis RF Co. - Bury-FLEX Flexible Low-Loss Coax Excellent cable and a great company to deal with. Be careful if you see the Bury Flex listed somewhere else cheaper. I read on another list the other day that the Chinese are producing a knock-off cable and labeling it as Bury-Flex.
Hope this helps!!
Wayne C.
__________________
"To be is to do"-Socrates;
"To do is to be"-Sartre;
"Do Be Do Be Do"-Sinatra;
WV4L,CDX-787,AK2787
Mobile/Base
Icom706MkIIG/Kenwood TS-2000 w/LDG AT-1000
Stock mic or W2ENY headset on VOX/D104 w/Heil HC-5 or W2ENY headset on VOX
High Sierra 1800Pro w/N2VZ Turbo Tuner,Larson NMO 2/70B/TX-472 tower w/ 80M Horizontal Delta Loop, 20-6M K4KIO Hex beam, Gulf Alpha Dual Band Cross Polarity 7X7El. 2M:10 El.v70 CM beam, Arrow 146-440GP
Ameritron AL80A
  #27
Old 02-16-2012, 02:58 PM
Senior Member
Default
Hmm.. it has .2DB more loss than lmr 400 at 50 mhz.. it is flexible tho, i dont really need that, but then again is .2b ever going to be noticed in the real world
Just got off the phone with them, ive used CNT 400 before, and they claim its the same as LMR 400, which i agree with, going to get some in the next few weeks.
  #28
Old 02-16-2012, 05:38 PM
Senior Member
vo1ks is on a distinguished road
Default
Confirm availability and price of connectors before you order the cable!
Not all cable and connector manufacturers make compatible pieces.
  #29
Old 02-16-2012, 06:17 PM
Senior Member
Default
Well, my Larcan has made it to its first destination on its way to me, and pics indicate it was very well packaged by warren, thanks a lot, and Garth for informing me about them, there appears to be some defacing done to the board, i didn't notice at first as i was hauling a full load while looking at the pic on bbm, however warren indicated it appears graffiti is on the board, i will have to check and am requesting better pics from my girlfriend. Although i do believe Garth is to blame here
Above was ment to be on my amp thread
This was for this thread
Thanks Warren will do.
  #30
Old 02-22-2012, 09:37 PM
Senior Member
KM3F is on a distinguished road
Default
In the northeast US, nearly every morning after 8am, a group gets on 144.205 SSB.
The better stations are working well over 300 miles over mountain terains.
My station is not of that calibere but still routinly work out to 300 miles off a single 12 element M2, 100 watts with a KW480 driving a Transverter.
My location on the eastern border of Pa. allows me to get as far as Toronto, Canada to the north, Columbus ,OH area to the west and N.C. to the south.
The need for high gain antennas, height, good receiver sensitivity and low loss coax is the way to go.
A hint here it to say that a low end station needs a lot of antenna gain and a good rotor and pay attention to zeroing in on direction.
The better contest grade stations with a lot of height have a of of power but use stacked lower gain antennas to get wider beam width and still have the gain of larger antennas, so rotor movement is not so critical.
I have chosen to go with N type connectors for the best overall performance.
Here in PA we seldom get any good enhancement in tropo conditions.
A check of the HEPBURN website can often show an enhancement prediction coming that could provide possible conditons to work more areas or longer distances.
The FLA area is often very hot for good tropo action.
This is just part of Ham radio just to see what can be done dispite the special equipment that is needed to make it happen.
I am beginning a new band for the same challange. 432 SSB with the same type setup and power to see what happens over time.
The equipment is in place and working. Now to get the tower back up with it's 6m, 2m, and 432 beams remotely switched to the same 1" Heliax very low loss transmission line.
The best conditions are coming in May through AUG with the VHF contest in June. Then the bands come alive for a good time from 6m all the way to 10 gigs..
This should give you some idea what might happen and you would be a Trophy contact on any of these bands, once they know your there.
Use E-mail to tell some when your trying and soon many will be looking for you everyday.
I forgot to mention that on 2m and up there are seldom ever any DX conditons as you might know it from 6m down.
Most often the conditions for longer distances involve weather patterns of Hot and cold boundry layers between fronts, and another thing called Ducting on 2m up.
The Ducting occurance can carry a signal beyond the normal tropo distances with very little ERP in use. You just have to be there at the right time.
Beacons are usefull at all times to tell what may be happening on any given band..
Good luck.
  #31
Old 03-21-2012, 05:23 AM
North Florida
WA8ZYT is on a distinguished road
Default
Michael, you will be welcome DX to all us Florida 2m SSB operators. Can't wait to work you. GL on the antenna system install.
The Florida SSB Net operates on Monday nights at 7 PM EST. Net control ops are in the Cocoa Beach area.
  #32
Old 03-21-2012, 05:26 PM
Senior Member
Default
thanks for the info, will be on the air in the next month or so.
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
