Go Back   WorldwideDX Amateur Radio Forums > Amateur Radio Related > Amateur Radio Antennas
Amateur Callsign Lookup
Enter Callsign:
B-Square J-Pole
Reply
  #9
Old 02-19-2012, 08:16 AM
Need2Know's Avatar
KK4GMU - The Villages, FL
Need2Know is on a distinguished road
Default
OK. My confusion was between ominidirectional and isotropic. Omindirectional is focusing on horizontal dispersion/reception; isotropic is equal dispersion in all directions, horizontal, vertical and everything inbetween.
An omnidirectional antenna attempts to flatten the isotropic theoretical (as in the "ball" example.) The energy that would have gone up and down with an isotropic antenna is directed to goe out "fairly" uniformly in all horizontal directions. So the gain of an antenna is the degree to which it can redirect the energy from being wasted going "up" or "down" and focusing it outward horizontally (if that is the desired direction of the signal.)
A directional or beam antenna focuses the signal even more compactly in a specific direction thereby achieving a higher db in the focused directions than what an omni could achieve.
I need to recall some of Mr. Wizard's experiments.
__________________
The more I learn, the more I realize that I don't know a lot more than I thought I didn't know.
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Push Up Pole HomerBB CB Antennas 27 03-18-2012 07:12 AM
J pole and ground Se7en VHF/UHF Bands and VHF/UHF Rigs 2 12-29-2011 09:05 AM
how effective is a j pole antenna on 11 meters ? BOOTY MONSTER CB Antennas 18 08-21-2010 05:59 PM
Need Help Building a dual band J Pole Antenna for 146/440 quiksilver199324 Amateur Radio Antennas 6 11-29-2008 09:27 PM
push up pole and 5'tripod radioreddz CB Antennas 3 12-13-2006 02:34 PM
Powered by vBulletin®
