Go Back   WorldwideDX Amateur Radio Forums > Amateur Radio Related > Amateur Radio Antennas
Amateur Callsign Lookup
Enter Callsign:
Broadband antenna for rx only
Like Tree1Likes
Reply
  #1
Old 02-29-2012, 11:19 AM
Need2Know's Avatar
KK4GMU - The Villages, FL
Need2Know is on a distinguished road
Default Broadband antenna for rx only
In understand that the stock antennae on most HT's provide minimal performance.
For the Kenwood TH-F6A, (receives 0.1 through 1300MHz), what antenna or antennae would produce significant improvement below 100MHz short of going to an outdoor antenna? I will have a dual band attic mounted J-pole for 2 meter/70cm.
Are there any recommended radio-mount antennae that would result in significant improvement over the stock rubber ducky?
Anyone with experience with in-room mounted (semi-)long wire for receive only?
Other options, e.g. in-room long wire with antannae amplifier?
__________________
The more I learn, the more I realize that I don't know a lot more than I thought I didn't know.
  #2
Old 02-29-2012, 09:47 PM
Beetle's Avatar
Senior Member
Beetle is on a distinguished road
Default
Experiment.
On my first receiver, circa 1958, I used a piece of 22ga. bell wire running diagonally across my bedroom ceiling, then down to the antenna terminal. Maybe 14 feet altogether. I heard just about everything from AMBC up through the ten meter ham band, and I heard it well enough to accumulate a few hundred SWL QSL cards before I got my Novice license.
I've never used the TH-F6; I wouldn't think it would be as good as the old Hallicrafters for MW and HF.
But, to reiterate: experiment.
__________________
If you're like everybody else,
you're about average.
73 de K7KBN
CWO4 USNR RET.
  #3
Old 03-02-2012, 02:35 PM
Moleculo has disabled reputation
Default
Sure, I did that when I had that same radio. It will definitely help. Another one you might look at is building a magnetic loop
  #4
Old 03-02-2012, 10:32 PM
Need2Know's Avatar
Default
A magnetic loop for receive only like this one?
A Magnetic Loop Antenna for Shortwave Listening (SWL) - KR1ST
What are the input gain pattern over the range of freqencies handled by the F6 on various length "long wire" antennas? Do variable capacitors have a similar effect on long wires as they do on the magnetic loop exaample above?
Have you applied variable capacitors to long wires?
__________________
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
