Go Back   WorldwideDX Amateur Radio Forums > Amateur Radio Related > Amateur Radio Antennas
Amateur Callsign Lookup
Enter Callsign:
Lightning and Attic Antennas
Reply
  #1
Old 03-18-2012, 09:22 AM
Need2Know's Avatar
KK4GMU - The Villages, FL
Need2Know is on a distinguished road
Default Lightning and Attic Antennas
On a scale of 1 to 10, with 10 being "I'll shoot my eye out" and one being "go ahead and give him the BB gun", how much should I worry about an ungrounded antenna in my attic.
I have professionally installed lightning rods all over my roof. But I am told even a near strike can charge the antenna and fry my system. That's never happened to any other equipment in my house tied to the cable TV or phone system in 4 years in the lightining capital of the western hemishere, central Florida.
__________________
The more I learn, the more I realize that I don't know a lot more than I thought I didn't know.
  #2
Old 03-18-2012, 10:09 AM
Jock Supporter
mackmobile43 is on a distinguished road
Default
Remember that newer units are laden with mosfet devices which are sensitive to static charges.
No more worry than you having lightning rods mounted to attract lightning to your home.
I would have them in the tops of trees around my home.
  #3
Old 03-18-2012, 06:20 PM
Need2Know's Avatar
Default
Quote:
Wrong. Lightining rods provide the path of least resistance for lightning to enter the ground through paths OTHER THAN the house. It is the same principle as providing the path of least resistance when grounding an antenna. Having rods in adjacent trees is not likely to reidrect lightning strikes.
HowStuffWorks "Lightning Rod"
__________________
  #4
Old 03-18-2012, 06:27 PM
pro151's Avatar
Just a friendly CB guy.
pro151 is on a distinguished road
Default
You could build a static dissipation array.
__________________
MASTER TROLL
Don't confuse my personality with my attitude.
My personality is who I am.
My attitude depends on who you are.
  #5
Old 03-18-2012, 06:50 PM
Jock Supporter
Default
"If you build it they will come" I'm Right and I live in a region that records as many lightning strikes as Florida and back in the 30's and 40's the snake oil salesmen sold millions of units "lightning rods" to poor unsuspecting dolts and many of them lost homes to lightning strikes that may have never occurred if they did not attract the lightning.
Nowadays no one here would even think of mounting something like that anywhere near their homes for just that reason and if it were such a hot idea it would be building code and not just the bullshit you're handing out here.
  #6
Old 03-18-2012, 06:52 PM
Jock Supporter
Default
Quote:
More efficient warding off lightning strikes than any freaking lightning rod.
  #7
Old 03-18-2012, 06:57 PM
pro151's Avatar
Default
The theory behind the dissipation array is to bleed the charge to ground before it becomes a full blown strike.
I see the umbrella type on a lot of small towers around Alabama and have seen the arrays on broadcast towers that resemble throwing stars on stalks.
I am sure Capt. KW has had some experience with them and will chime in on this thread at some point.
Some swear by them. Some swear at them.
__________________
MASTER TROLL
  #8
Old 03-18-2012, 07:13 PM
Jock Supporter
Default
I'll take several pieces of small diameter steel cable frayed at one end then attached to the chassis and cab of semi trucks and this totally eliminated static shocks when leaving the vehicles.
Them lightning rods cb antenna never did that for me! I know those are above ground of the vehicle but it sounds really good if you know know all the snake oil technologies.
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Attic wire dipole bandwidth joker535 CB Antennas 1 12-06-2011 06:04 PM
Powered by vBulletin®
