Go Back   WorldwideDX Amateur Radio Forums > Amateur Radio Related > Amateur Radio Antennas
Amateur Callsign Lookup
Enter Callsign:
What balun or unun for these vertical antennas?
Reply
  #1
Old 05-04-2012, 11:54 AM
Moleculo has disabled reputation
Default What balun or unun for these vertical antennas?
I saw this portable vertical antenna on ebay and am thinking about building one for myself:
PROWHIP PORTABLE HF ANTENNA, 160M - 6M , hieght 10M | eBay
I believe with these antennas they're using an UNUN, to get it to load up 160-6m right? Does anyone directions on how to build it properly?
  #2
Old 05-04-2012, 12:51 PM
KC9Q's Avatar
Contributing Site Sponsor
KC9Q is on a distinguished road
Default
Here's a web site that shows the winding method.
http://www.angelfire.com/electronic2/qrp/unun.html
However for high power use 14 bifilar windings of #14 insulated wire on a FT240-K core. If you need to; connect any ground radials to the SO-239 shield side.
That should do it.
  #3
Old 05-04-2012, 02:16 PM
hookedon6's Avatar
hookedon6 is on a distinguished road
Default
I "think" these are made by G7TAS
www.prowhipantennas.co.uk/
and use his 400 wattbalun
  #4
Old 05-04-2012, 06:35 PM
Crotchety Old Bastard
W5LZ is on a distinguished road
Default
For multiband use, those baluns/ununs better be adjustable...
  #5
Old 05-22-2012, 07:27 AM
Junior Member
WD4FCJ is on a distinguished road
Default vertical antenna
looks like the one i built. only mine is 10 thru 40 meters. a fiberglass telescopic shaft with a 23 ft wire inside and a 4:1 balun. matching radials. some say radials are not not nec. but i am getting very good results with radials.. check out this link for a 4:1 balun. easy to make..about $10.00 us dollars
RogerTango.com - Build a 4:1 voltage BALUN
Reply
Bookmarks
Tags
balun, unun
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Super C antenna...this is really neat Moleculo Amateur Radio Antennas 14 01-19-2014 02:04 PM
Circular Polarized Antenna Pushrod CB Antennas 30 05-01-2011 08:22 AM
the truth according to Firestik (get a drink and a snack , LOL) BOOTY MONSTER CB Antennas 14 04-20-2011 07:50 PM
1/4 wave groundplane & end fed verticals - time for some FACTS Moleculo CB Antennas 31 03-30-2009 11:51 AM
baluns towernewbie Amateur Radio Antennas 16 03-02-2008 04:11 AM
Powered by vBulletin®
