Go Back   WorldwideDX Amateur Radio Forums > Amateur Radio Related > Amateur Radio Antennas
Amateur Callsign Lookup
Enter Callsign:
New Cushcraft Squalo Antennas
Like Tree1Likes
Reply
  #1
Old 08-01-2012, 03:51 PM
Moleculo has disabled reputation
Default New Cushcraft Squalo Antennas
The following is a press release from Cushcraft regarding new Squalo antennas:
New! Cushcraft 6-Meter & HFSQUALO (TM)” Antennas!
ASQ-2,2-Meter, 10x10 inches, $119.95
ASQ-6, 6-Meter, 30x30 inches, $139.95
ASQ-10, 10-Meter, 50x50 inches, $159.95
ASQ-15, 15-Meter, 65x65 inches, $189.95
ASQ-20, 20-Meter, 100x100 inches, $229.95
Cushcraft’s SQUALO (TM) is a full half-wave, horizontally polarized omni-directional antenna. Outstanding all-around performance is achieved through a 360 degree pattern with no deep nulls.
The square shape allows full electrical length in compact dimensions. Direct 52 Ohm Reddi-Match(TM) feed provides ease of tuning and broad band coverage. Cushcraft Squalo(TM) is well suited for horizontally polarized mobile or fixed operation on SSB, CW, and legacy AM.
The omni-directional pattern is great for DX beacons and spotting, and elements may be stacked for added gain. The Cushcraft Squalo(TM) is completely universal for mounting anywhere. Each is packaged with rubber suction cups and magnets for vehicle top mounting, 2 and 6 Meters and a horizontal center support for mast or tower mounting.
The 10, 15, and 20 Meter models are designed for mast or tower mounting. Cushcraft Squalos (TM) are ideal for net-control, monitoring or as a general coverage antenna. Each is factory tuned for minimum SWR and handle 100 Watts PEP CW/SSB.
Cushcraft SQUALOS(TM)carry a one year limited warranty.
To order, receive a free catalog, or for your nearest dealer, call 1-800-973-6572; or write to: Cushcraft, 308 Industrial Park Road, Starkville, MS 39759; or go online: http://www.cushcraftamateur.com; or fax to: 1-662-323-6551.
Se7en likes this.
  #2
Old 08-01-2012, 06:20 PM
TonyV225's Avatar
TonyV225 is on a distinguished road
Default
Tim Ironically I was just looking at these the other night and cant figure out how exactly these things work. Crazy looking forsure!!
__________________
""""was not thinking of a cber sat with his makita screwdriver winding round the presets untill his meter said s9+60db from a guy on a handheld 15 miles away""""
  #3
Old 08-01-2012, 06:59 PM
Wire Weasel's Avatar
Senior Moment
Wire Weasel is on a distinguished road
Default
I am disappointed by the mere 100 watts power handling and the high cost of the bigger ones. The sturdy construction makes 2 meter model a reasonable choice for mobile use and the 6'er is a possibility too. I don't see the point of the 10,15 or 20M models. Not practical for mobile use and existing vertical antennas have always gotten the job done. For using the 10,15 or 20 at home I would use a Loop made from wire, get the same omni pattern and one made for 20M would also do the other bands. Plus your typical 14g a copperweld antenna wire will take 2kw. Make a Loop and take yourself out to Longhorn's for dinner several times with the savings ...... including drinks :-)
__________________
Welcome to the WWRF. Plenty of Free Parking and with 5,000 posts you get egg roll
  #4
Old 08-01-2012, 08:31 PM
KC9Q's Avatar
Contributing Site Sponsor
KC9Q is on a distinguished road
Default
What a difference from the original Squalo products that used a gamma match. I beleive the old units were also 100 Watts, but there is no power spec published for either the ASQ-6, 6 Meter; or the ASQ-2, 2 Meter models. Prices sure have changed: from a 1975 catalog the ASQ-6: $15.95, and the ASQ-2: $11.95.
  #5
Old 08-01-2012, 08:56 PM
Se7en's Avatar
Se7en is on a distinguished road
Default
I was just thinking how much more room i have on my Extended TB for another antenna!!
I like it! and since i just purchased a VX-7R with 6m FM and 1w AM on 6 this would be a cheap expensive antenna for that magical band!
__________________
  #6
Old 08-01-2012, 10:05 PM
IMD262's Avatar
Senior Member
IMD262 is on a distinguished road
Default
Is there a lot of horizontal FM on 6M on the west coast???
  #7
Old 08-01-2012, 10:21 PM
Se7en's Avatar
Default
Quote:
You just had to ruin my dream of making qso's with a ht and verttenna on the magic band :o
__________________
  #8
Old 08-02-2012, 07:32 PM
Senior Member
ElectronTubesRule is on a distinguished road
Default
Why would you want to run polarized horz. versus vert. on a mobile st up? I can see being able to select either or for a fixed base but in those bands vert. seems the best way to go? Am I am missing something?
I am guessing the limiting factor for power is the Balun they are using the rest of it looks like aluminum tubing surely it is able to take more power then tin foil if the balun is beefed up you would think? Is this the case is the matching network the limiting factor? Also they mention you can stack them for gain. Can the suction cups and magnets real take stacked setup going 55mph or better or would you have to be parked to stack them? Just asking because I have never heard of this setup ever being used on a mobil let alone stacked and with magnets or suction cups????
I am waiting to see a Canadian car come into Michigan with a stacked set of 10 meter antenna's like this...... They will supported from the hood and rear bumper......LOL Everyone in Michigan drives too fast for those they would exceed their wind load limt is in seconds especially near Detroit where everyone drives 95+++MPH....LOL
Are those hose clamps on that antenna? I know I am being a bit harsh or sound like I do not mean to be. I just think it looks like something one of us would build in our back yards and have come to expect a bit more refinement from store bought items. The hose clamps are what really turn me off. I do not like those on car's let alone on an antenna that will be mounted on a car.
Reply
Bookmarks
Tags
cushcraft, squalo
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
the truth according to Firestik (get a drink and a snack , LOL) BOOTY MONSTER CB Antennas 14 04-20-2011 07:50 PM
Difference between 2m and 70cm HT antennas? ke7vvt Amateur Radio Antennas 2 01-17-2010 04:33 PM
MFJ Acquires Cushcraft ARRL ARRL Updates 0 08-07-2009 05:10 PM
Cushcraft now owned by MFJ Moleculo Amateur Radio Antennas 0 08-07-2009 11:18 AM
baluns towernewbie Amateur Radio Antennas 16 03-02-2008 04:11 AM
Powered by vBulletin®
