Go Back   WorldwideDX Amateur Radio Forums > Amateur Radio Related > Amateur Radio Antennas
Amateur Callsign Lookup
Enter Callsign:
Larsen 27 MHz NMO Stinger diameter ???
Like Tree1Likes
  • 1 Post By VA3ES
Reply
  #1
Old 03-10-2013, 02:18 PM
m42duster's Avatar
Senior Member
m42duster is on a distinguished road
Default Larsen 27 MHz NMO Stinger diameter ???
I was wondering if anyone knows if a Wilson 1000/5000 stinger is the same diamet as the stock Larsen stinger. I have 3 Wilson stingers at the QTH. Just trying to save some cash by only buying the Larsen coil base.
And what's up with Larsen magnet mount bases only having 12' of coax?
  #2
Old 03-10-2013, 05:34 PM
m42duster's Avatar
Senior Member
Default
Oh well, I'll find out. Just ordered one.
  #3
Old 03-30-2013, 02:00 PM
m42duster's Avatar
Senior Member
Default
Tried a magnet mount and a trunk lip mount. No matter what I did, I could not get SWR below 1.7.
Slapped my old K40 trunk mount back on for now.
  #4
Old 03-30-2013, 03:17 PM
towerdog's Avatar
one-niner-seven
towerdog is on a distinguished road
Default
I just got a Midland trunk lip NMO antenna, looks identical to a Laird (similar to larsen) and same specs too. In a few minutes I plan to get up, take the NMO connector apart from the trunk lip base and drill a hole in the roof of my VW because trunk lip mounts are almost useless below 100mhz and then you need some good electrical bonding of the trunk to the body.
The instructions for mine call for cutting the whip for different frequencies and a cutting chart is supplied. If SWR is lower on channel 1 than 40, try cutting 1/2" off and check again.
  #5
Old 04-03-2013, 04:37 AM
VA3ES's Avatar
Old Buzzard
VA3ES is on a distinguished road
Default
The Larsen NMO27 antenna was strictly designed for commercial use in the 27 – 30MHz range. It was never designed for amateur radio use, or for long distance ground wave or DX applications. It was designed to provide a good, robust antenna for commercial mobile applications such as logging and mining operations. The 49” whip is perfect for trucks that can’t handle longer whips, and it provides a robust compromise. The Larsen NMO27 is a commercial low-band antenna, and as such was designed to be robust and easily field replaceable. It is a compromise. It was designed to allow trucks to communicate with a remote base within ground wave range. It is entirely unsuitable for amateur (or CB) use.
Here is what we use instead – the Larsen NMO34 system. The Larsen NMO34 system uses the Larsen NMO34 coil, a 64” whip and a spring to provide a high efficiency and high performance antenna that compares favourably to the Wilson 1000 series. The total length of the antenna is approximately 70”. It works exceedingly well, and with over 15 users locally in the Ottawa area, we have rave reports and excellent results.
The antenna is NOT normally commercially available, but must be custom ordered . You will need the following parts: the NMO34 coil (NMO34B) the 64” whip (W-640B) and the spring (SPRINGB). This can be ordered from any Larsen dealer.
Finally, it is compatible with all Larsen NMO mounts, so you can swap it out with any Larsen NMO-type VHF antenna.
File Type: pdf New 10M antennas that fit NMO mounts.pdf (51.3 KB, 20 views)
m42duster likes this.
__________________
Ed - VA3ES
AMI #529
QCWA #28666
10-X #11131
  #6
Old 04-03-2013, 02:08 PM
m42duster's Avatar
Senior Member
Default
Interesting read.
  #7
Old 04-03-2013, 03:29 PM
BANNED
High Voltage Mobile NJ is on a distinguished road
Default
most of the new wilsons for the past 5 years or so have to be cut 1/4 to 3/4 of an inch to get a 1.1 swr . the usally tune very low but below 27mhz stock , until you cut the whip down a few .
  #8
Old 04-03-2013, 03:31 PM
m42duster's Avatar
Senior Member
Default
I was referring to the Larsen.
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
10 meter mobile, 102 whip vs Larsen NMO 27 (or similar) mr_fx Amateur Radio Antennas 8 02-18-2013 08:21 PM
Yaesu Vx-8 & VX-8DR Mars Cap & Freeband Mods tlordon Yaesu 9 01-31-2013 11:47 AM
11 meter freq's from around the world. DXman General CB Services Discussion 11 12-09-2011 06:32 AM
CB Radio Cobra 19DXIV and Larsen NMO 27B darrenster CB Radio Gear SwapShop 0 01-05-2011 04:27 PM
Larsen NMO 27B Frequency Change darrenster Amateur Radio Antennas 8 12-27-2010 04:41 PM
Powered by vBulletin®
