WorldwideDX Amateur Radio Forums
WorldwideDX Amateur Radio Forums (http://www.worldwidedx.com/forums.php)
-   Amateur Radio Antennas (http://www.worldwidedx.com/amateur-radio-antennas/)
-   -   Super Loop UHF Beams Co-Phased Array (http://www.worldwidedx.com/amateur-radio-antennas/153220-super-loop-uhf-beams-co-phased-array.html)
Monkee 04-12-2013 10:41 PM
5 Attachment(s)
{Moved to Amateur Radio Antenna Section to allow greater participation in thread -Moleculo}
Hello Gents:
Here is the long awaited Super Loops UHF Co-Phased Beams with full specs. Can't wait until I pump couple kw into this setup, need to see if I can contact E.T.
Henry (k9kao)
Scrap'r 04-13-2013 02:51 PM
Hmmmm... No mas horizontal elements? I wonder if the whole vert/horz polarization motor idea is out the window...
Scrap'r 04-13-2013 03:14 PM
1 Attachment(s)
Quote:
I guess for those readers that haven't been following the local development of KI6IUJ's "SuperLoop", I should clarify my comment above...
I've had a 2M SuperLoop for over a year now. In fact, it's serial #002. I love it. One of the features is that the driven element is set up to rotate 90 degrees changing the polarization from vertical to horizontal via a remote control. While this can be done with more than one feed point, doing it physically has a number of advantages when it comes to both loss and pattern.
Gregg/IUJ has changed gears on the motor assembly, which required him to make to new housing molds, etc... I was going to post a review on the set-up once all of the bells and whistles were in the air. I still will (Gregg? Motor?) once I finish it up.
Attachment 9800
This is the five element model due to space issues that I have, but his eight element and stacked eight element units are killers.
KI6IUJ - SuperLoop 05-07-2013 11:03 AM
UHF VHF Contest Season is Almost Here
Hey Henry, I too am looking forward to using a stacked pair. Need that power-divider. I would also like to remind everyone that 446.000 FM simplex is a fun place to test your stations effectiveness. While there is not a lot of traffic there, there are diehard UHF folks lurking, so give it a try. 73 - Gregg aka-SuperLoop
Moleculo 05-07-2013 08:55 PM
So when are they going to be generally available and what will be the cost? Also, do you have plots and specs for the 2m antenna?
KI6IUJ - SuperLoop 05-09-2013 12:39 PM
2 meter SuperLoops
8 Attachment(s)
2-meter SuperLoops as well as 70 cM SuperLoops are all available. For more info email me at: s9radio@aol.com
Hello,
Powered by vBulletin®
Worldwide Radio Forum
