Go Back   WorldwideDX Amateur Radio Forums > Amateur Radio Related > Amateur Radio Antennas
Amateur Callsign Lookup
Enter Callsign:
Super Loop UHF Beams Co-Phased Array
Like Tree1Likes
  • 1 Post By Monkee
Reply
  #1
Old 04-12-2013, 10:41 PM
Monkee is on a distinguished road
Default Super Loop UHF Beams Co-Phased Array
{Moved to Amateur Radio Antenna Section to allow greater participation in thread -Moleculo}
Hello Gents:
Here is the long awaited Super Loops UHF Co-Phased Beams with full specs. Can't wait until I pump couple kw into this setup, need to see if I can contact E.T.
Henry (k9kao)
  #2
Old 04-13-2013, 02:51 PM
FatHam's Avatar
Senior Member
FatHam is on a distinguished road
Default
Hmmmm... No mas horizontal elements? I wonder if the whole vert/horz polarization motor idea is out the window...
__________________
http://www.worldwidedx.com/image.php?type=sigpic&userid=19127&dateline=1398527563
  #3
Old 04-13-2013, 03:14 PM
FatHam's Avatar
Senior Member
Default
Quote:
I guess for those readers that haven't been following the local development of KI6IUJ's "SuperLoop", I should clarify my comment above...
I've had a 2M SuperLoop for over a year now. In fact, it's serial #002. I love it. One of the features is that the driven element is set up to rotate 90 degrees changing the polarization from vertical to horizontal via a remote control. While this can be done with more than one feed point, doing it physically has a number of advantages when it comes to both loss and pattern.
Gregg/IUJ has changed gears on the motor assembly, which required him to make to new housing molds, etc... I was going to post a review on the set-up once all of the bells and whistles were in the air. I still will (Gregg? Motor?) once I finish it up.
This is the five element model due to space issues that I have, but his eight element and stacked eight element units are killers.
__________________
  #4
Old 05-07-2013, 11:03 AM
KI6IUJ - SuperLoop's Avatar
Junior Member
KI6IUJ - SuperLoop is on a distinguished road
Default UHF VHF Contest Season is Almost Here
Hey Henry, I too am looking forward to using a stacked pair. Need that power-divider. I would also like to remind everyone that 446.000 FM simplex is a fun place to test your stations effectiveness. While there is not a lot of traffic there, there are diehard UHF folks lurking, so give it a try. 73 - Gregg aka-SuperLoop
  #5
Old 05-07-2013, 08:55 PM
Moleculo has disabled reputation
Default
So when are they going to be generally available and what will be the cost? Also, do you have plots and specs for the 2m antenna?
  #6
Old 05-09-2013, 12:39 PM
Junior Member
Default 2 meter SuperLoops
2-meter SuperLoops as well as 70 cM SuperLoops are all available. For more info email me at: s9radio@aol.com
Hello,
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Super C antenna...this is really neat Moleculo Amateur Radio Antennas 14 01-19-2014 02:04 PM
Yaesu FT-51R Dual Band VHF UHF Transceiver Paging Ham Radio Amateur SUPER NICE Ebay Amateur Gear eBay Auctions Ending Soon 0 03-28-2012 11:30 AM
Yaesu FT-51R Dual Band VHF UHF Transceiver Paging Ham Radio Amateur SUPER NICE Ebay Amateur Gear eBay Auctions Ending Soon 0 03-21-2012 10:10 AM
Yaesu FT-51R Dual Band VHF UHF Transceiver Paging Ham Radio Amateur SUPER NICE Ebay Amateur Gear eBay Auctions Ending Soon 0 03-07-2012 06:20 AM
Interesting variation on a delta loop or folded dipole Moleculo Amateur Radio Antennas 9 12-28-2010 06:12 AM
Powered by vBulletin®
