Go Back   WorldwideDX Amateur Radio Forums > Amateur Radio Related > Amateur Radio Antennas
Amateur Callsign Lookup
Enter Callsign:
TAK ANTENNA
Reply
  #9
Old 02-18-2008, 08:55 AM
Captain Kilowatt's Avatar
Professional Amateur
Captain Kilowatt is on a distinguished road
Default
Quote:
Originally Posted by freecell View Post
"10 to 14 dB signal increase in transmit with 90 degree rotation"
that's some funny stuff.
What's so funny about it? It does not say the antenna exhibits that much gain. A rotatable dipole will do at least the same thing. Orienting the antenna null towards a station and then rotating it to a peak,even if that peak is down from a dipole, should show a differance of at least 10-14 dB.It is comparing relative losses,not true gains.My external tuned ferrite bar antenna will show better than 30 dB signal increase with a 90 degree rotation on the AM broadcast band. Not bad for an antenna 10 inches long on a wavelength of 200m or more. It's all about the nulls not the gains.
  #10
Old 02-18-2008, 04:00 PM
Senior Member
WA1BXY is on a distinguished road
Default
well after all this discusion i have one and its on the tower i see less rx then my windom which is 10ft lower then this antenna and also i see hardley any directivity out of this antenna. as many know i run cw 99.9% of time and on the windom for instance i get an s9 "599" and on this antenna pointing at them away from them on the side no difference i get an s5 to s6"569 559".. so i cant say the it has much directivity. now on foward gain.. once again windom blows it away. i receive 599 and on this antenna i get 549 to same person.. so i does make a great back up portable emergency antenna hands down but for every day use not recomended..
__________________
www.wa1bxy.webs.com
WA1BXY
Coordinates: 41.615063 -71.168688
State: Rhode Island
County: Newport
Town: Tiverton
Grid: FN41jo
Area Code: 401
GMT Offset: -5
Time Zone: Eastern
Has DST?: Y
Born: 1981[FONT=Optima]
  #11
Old 02-18-2008, 04:43 PM
Default
Just like I said,it's not about the gains but the relative losses from peak to nulls.
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://www.worldwidedx.com/amateur-radio-antennas/28639-tak-antenna.html
Posted By For Type Date Hits
tak antenna | VIRGILIO Ricerca | Web This thread Refback 08-29-2009 12:10 AM 1
tak antenna | VIRGILIO Ricerca | Web This thread Refback 02-14-2009 02:54 AM 1
tak antenna | VIRGILIO Ricerca | Web This thread Refback 02-12-2009 12:25 PM 1
Powered by vBulletin®
