Go Back   WorldwideDX Amateur Radio Forums > Amateur Radio Related > Amateur Radio Antennas
Amateur Callsign Lookup
Enter Callsign:
TAK ANTENNA
Reply
  #1
Old 02-16-2008, 05:28 PM
Senior Member
WA1BXY is on a distinguished road
Default TAK ANTENNA
ANYONE EVER GIVE ONE OF THESE A TRY YET?
__________________
www.wa1bxy.webs.com
WA1BXY
Coordinates: 41.615063 -71.168688
State: Rhode Island
County: Newport
Town: Tiverton
Grid: FN41jo
Area Code: 401
GMT Offset: -5
Time Zone: Eastern
Has DST?: Y
Born: 1981[FONT=Optima]
  #2
Old 02-16-2008, 07:41 PM
Crotchety Old Bastard
W5LZ is on a distinguished road
Default
Never heard of it. What is it?
  #3
Old 02-16-2008, 08:13 PM
AudioShockwav's Avatar
Extraterrestrial Admin
AudioShockwav has disabled reputation
Default
http://www.tak-tenna.com/
And the reviews on Eham.com
Reviews: 34 Average rating: 4.9/5 MSRP: $108 Description: Electrical Half-wave Dipole Antenna
Rotatable - Portable - Stealth - Perfect Backup Antenna
Currently available in 40m, 20m, 10m, and 11m models
Electrical Quarter-wave radiating spiral end elements
Direct feed with 50 ohm coax on resonant band
User selects resonant frequency during tuning process
Can use coax + tuner...or twin lead + tuner
Power tested to 1000 CW watts,
key down for 30 seconds and 1400 Watts PEP
no heat sensed on antenna wire or coax feed point when touched by hand after power testing
NO lossy matching components anyplace in system
10 to 14 dB signal increase in transmit with 90 degree rotation
30 inch boom
Low SWR across band
Sturdy and well built
Weighs only 5 pounds
Uses proprietary #14 gage copper plated alloy wire
Easy assembly - less than 90 minutes
TAK-tenna 40 Multi-Bander also works on 30, 20, 15 and 10 Meters with use of tuner
Tested with Kenwood TS-430 and AT-250 using 50 ohm coax to antenna
Tested with twin lead and other tuner...works fine too
http://www.eham.net/reviews/detail/6775
__________________
Radio-active
NASA/SOHO
When I was a child
I caught a fleeting glimpse
Out of the corner of my eye.
I turned to look but it was gone
I cannot put my finger on it now
The child is grown,
The dream is gone.
but I have become comfortably numb.
  #4
Old 02-17-2008, 06:24 AM
Default
Ah Ha! Now I remember, just didn't remember the thing's name. It's one of those things that are on my 'to-do' list, just haven't gotten that far yet.
Some thoughts and conjectures.
It's a small antenna. Want to say less obtrusive than a full length dipole, but that's debatable . Should be able to be almost over looked cuz it's sort of close to a TV antenna (nuther' debatable thingy). Say it's for HDTV!
It isn't an 'equal' substitute for a 'real-live' antenna, but it's certainly workable as a back-up as claimed by the advertising (I like the fact that 'they' aren't claiming it's the next 'miracle-do-everything-bestest' antenna around). And it can certainly fill an antenna requirement for 'back-up' or those hard to fit places, especially if you don't have the required 'spaces' to start with.
I have no reason to doubt the claims made for this thingy so far. So far, they haven't been that extraordinary, disregarding what the thing looks like. Used with the proper feed line and tuner, the 40 meter version ought'a be usable on bands higher than 40 meters. In that regard, it 'matches' the claims for the G5RV. And also like the G5RV, it don't 'do' miracles.
Like any rotateable 'dipole', it's directional to some extent. Getting it higher than the typical 15-25 foot altitude can't do anything but help that characteristic. I do like the fact that it would only require a 1/4 turn to cover all directions!
Easy to put together? There, I have my doubts, at least for me anyway. I've tried the 'spiral' thingy with other things and it does require paying attention to what you are doing! (Ended up too many times with a gob of spagetti when I've turned loose too soon.) Doesn't sound like it's too difficult though, sort of.
Enough of that. It's still on my 'to-do' list! I wanna see what it'll do. Scale it to size and it ought'a look great for 2 meters on my aluminum foil helmet, don't'cha think??
  #5
Old 02-17-2008, 07:19 AM
Senior Member
SR385 is on a distinguished road
Default
I was on the air with the guy who makes these on 80m the other night. It's no miracle antenna, but it does radiate. It's a great antenna for people who have no room to work with.
I've seen them up close at the local hamfests, it's solid enough but again, it's not a NASA design. It's plastic tubing for supports and is basically a dipole, center fed with the ends in a spiral. There may be more thought into the dimensions etc for electrical properties, but that's basically what it is.
The guy was running it on a rotor and there was a slight bit of difference within 90 deg turns so it does have some lobes to its pattern.
  #6
Old 02-17-2008, 10:08 AM
BANNED
freecell is an unknown quantity at this point
Default
"10 to 14 dB signal increase in transmit with 90 degree rotation"
that's some funny stuff.
  #7
Old 02-17-2008, 04:39 PM
Senior Member
Default
From the night I talked to the guy, it was maybe 1 S-unit as he rotated from peak to dip. Heh, no way it has that level of gain, and I'm close to where he was for sure and he was say an S7 where all the other locals on 100W rigs were S9+10 or better. He was just above the noise level.
  #8
Old 02-18-2008, 07:30 AM
guardian of freedom
rfoverlord is on a distinguished road
Default
maybe there was suppose to be a decimal.
"1.0 to 1.4 dB signal increase in transmit with 90 degree rotation"
that would be more like it. it looks like something comparable to a isotron, which is just as good as a dipole (compared to nothing) just more compact.
__________________
If you run, you'll only die tired.
CDX-251,2SF251,AE926, N9MSH
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://www.worldwidedx.com/amateur-radio-antennas/28639-tak-antenna.html
Posted By For Type Date Hits
tak antenna | VIRGILIO Ricerca | Web This thread Refback 08-29-2009 12:10 AM 1
tak antenna | VIRGILIO Ricerca | Web This thread Refback 02-14-2009 02:54 AM 1
tak antenna | VIRGILIO Ricerca | Web This thread Refback 02-12-2009 12:25 PM 1
Powered by vBulletin®
