Go Back   WorldwideDX Amateur Radio Forums > Amateur Radio Related > Amateur Radio Antennas
Amateur Callsign Lookup
Enter Callsign:
archer crosbow
Reply
  #9
Old 02-21-2008, 09:40 AM
Switch Kit's Avatar
Senior Member
Switch Kit is an unknown quantity at this point
Default
Is this a two piece and what color is it ?
  #10
Old 02-21-2008, 07:58 PM
fly442 is on a distinguished road
Default antenna
kind of green and it is 2 peice
  #11
Old 02-22-2008, 06:46 AM
Switch Kit's Avatar
Senior Member
Default
that should be it , just get it up as high as you can and it should work surprisingly well for you. Lord knows , I've used worse in my time. Peace
  #12
Old 03-01-2008, 05:09 PM
Junior Member
senator215i is on a distinguished road
Default
i got one its in bits and i cant figure out how to put it together anyone got some pics or a pdf
  #13
Old 03-01-2008, 07:06 PM
Default archer crosbow
if i can trade for it i will post picture's
  #14
Old 03-16-2010, 08:10 PM
Senior Member
15minigrass is on a distinguished road
Default
How many watts will it handle???? Im guessing 300 watts?
__________________
Mobile:
Prez Grant Export/Stock Mic
Black Widow 350V
Two 9" Predator 10K
RS SWR/Watt Meter
Base:
P/T COBRA 146GTL(Spare)
President Jackson
Turner +3 Hand Mic
Pyramid 25 Amp P.S.
Home Made Ground Plane Base ant.
  #15
Old 04-25-2010, 08:37 AM
Junior Member
A.CADWELL is on a distinguished road
Default
does anyone have the schematics for this antenna?
  #16
Old 06-06-2010, 02:41 PM
Transducer Fanatic
CDX-007 is on a distinguished road
Arrow
Quote:
If you're asking for schematics I would presume you may be referring to the 3 element Yagi? Those should be available from MFJ/Maco or on line.
The simple blue-green Archer Crossbow omni simply threaded together in the center (albeit a reverse thread, if I recall correctly) and mounted on a mast. It's basically a 100w pep 16' big stick. Why they decided to use a reverse thread at the center junction I'll never understand.
I gleaned one of the 96" blue fiberglass whips from a friend's Crossbow (which fell and splintered near the base) and rethreaded it for correct thread direction 3/8" x 24 and it makes a real nice mobile antenna on the 4-magnet mount.
It's a 100w antenna at best. It uses a small capacitor up inside to match the 72ohm center-fed dipole back down to 50ohms, and that capacitor tends to fry with any real power. - That's why you see so many of them not in use above homes, but in the landfill.
It's a center-fed dipole, and is basically a unity gain antenna. If you live in an area surrounded by hills or mountains, change out the 96" whip for a 7 foot Firestik, (which you'll have to rethread wackbirds) but it will help your signal to get up over and above the hills. I had success doing this in 1986 near Bodega Bay in the Ca coastal mountains and saw a marked improvement into town (Santa Rosa) using the 7' Firestik.
If it were me, I'd ebay it for as much as someone more nostalgic than knowledgeable (antenna-wise) will pay, then spend the cashola for a metal 5/8 like a Maco or equivalent.
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
