Go Back   WorldwideDX Amateur Radio Forums > Amateur Radio Related > Amateur Radio Antennas
Amateur Callsign Lookup
Enter Callsign:
push poles
Reply
  #1
Old 03-17-2008, 12:51 PM
Senior Member
4600turbo is on a distinguished road
Default push poles
I would like to put up a base station and I've been looking for the easiest way to do this,of course.
I found some fiberglass push poles that I can afford, but I was wondering if I should use metal instead.
Would a metal push pole be better than fiberglass for any reason.
Will my station perform better with a metal push pole or will the fiberglass one be just fine?
  #2
Old 03-17-2008, 01:21 PM
Moleculo has disabled reputation
Default
Your station won't perform any different from one to the other. Take a look at the weight of the two different push ups and also the strength. Depending on your antenna and guying plans, that may help shape your decision.
  #3
Old 03-17-2008, 01:39 PM
Senior Member
SR385 is on a distinguished road
Default
For an alternative that worked nicely for me, look at galvanized hurricane fence top-rail.
I used 20' of it to stick a vertical up on my roof. It's about $10 per 10' section here at Home Depot.
I took the slip joint and drilled it while coupled and stuck #10 sheet metal screws through the holes.
My mounting bracketed the base of the bottom section and the middle at the joint and the antenna is rock solid. If you went free standing with it, I would recommend guying at at least each 20' mark. You can tie three guys through stainless hose clamps on the pole.
If I had to guess, guyed twice, these things should easily hold 40'. The top ten foot section on mine barely moves at all in 40mph winds.
  #4
Old 03-17-2008, 02:29 PM
Registered User
JK_RUBICON is on a distinguished road
Default
What state are you in?
  #5
Old 03-17-2008, 05:39 PM
Senior Member
park is on a distinguished road
Default
I have never seen a fiberglass push pole?
__________________
Everyone drives like crap but me.
  #6
Old 03-17-2008, 06:15 PM
KingCobra_CDX882 is on a distinguished road
Default
ditto...
I never saw a fiberglass push up pole
If anything fiberglass should be better in that
will cause less interference with your SWR's
Beyond that i see little or no difference
If you want
try going to your local radioshack...
ask the manager if he has any old pushup poles that are not currant models
is likely he will be more then glad to give it to you for free
(that is how i got more then a few push up poles as well as 5 and 10 ft masts
  #7
Old 03-17-2008, 08:05 PM
Senior Member
Default
I've found a fiberglass one that will go 43'. It starts out at 2" ends as 3/4" and it only weighs 16 pounds.
I also thought of putting up the galvanized top rail as a pole I've go some that are 21' in length, but didn't think it would be that sturdy. I didn't want to do any guying ,since my property is small.
JK Rubicon I live in New Mexico.
  #8
Old 03-18-2008, 05:33 AM
Lazybones1222's Avatar
Lazybones1222 is on a distinguished road
Default
I did the same thing for a Maco V58 antenna. Cheap and effective.
__________________
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
