"How else does one ISOLATE the support mast from the base of the antenna? Obviously, if you do not put something between the mast and the antanna base, you will have continuity between the radials and the GROUND (via the mast), which is apparently undesireable (because of pattern skew and ground loss)."
If you're talking about a groundplane antenna, where the radials take the place of earth ground, there's really no point in doing that isolation thingy. The mast/support would only be adding to the ground, which ought'a be a good thing. That assumes that the mast/support does not extend above the antennas radials, in other words, is on the top of the mast.
"This is what I
am most interested in resolving. Does "isolating" the mast from the antenna base merely refer to using some kind of insulator between the two?"
That's certainly what it sounds like. Just to make sure, why not ask the manufacturer?
"I
am about to install an ELEVATED 43' Zerofive multiband vertical (10M-160M). I will be using an Array Solutions "Tuner" balun at the antenna base. Are these "Tuner" baluns considered a "current" type balun? Should I also add the dozen big (#73 material) beads (I have on hand) at the feedpoint as an extra common mode suppression tactic?"
Why not see if you need any 'additional' suppression first? they shouldn't hurt anything, but may not 'help' anything either.
No idea what those "Tuner" baluns are, voltage/current.
"And if I isolate this antenna from the mast, and do not run a ground cable, then what about lightning protection? Is there a cheap way to either create a spark gap (of sorts). If not, where would I obtain an INEXPENSIVE lightning arrestor to hook a ground cable to? I
am only going to be running 100 watts (for now)."
If the mast is a continuous 'conductor' going to ground, and if you isolate the antenna from the mast without adding a ground wire of some kind, no, you have no lightning protection. If you then add a ground wire from antenna to ground for that lightning protection, it seems like a complicated way of doing things to me. Why not just use that mast since it's already there? Makes me wonder about the use of 'isolate' and 'insulate', doesn't it you?
There is no 'INEXPENSIVE' way of arresting lightning. 'Spark-gap' type arrestors do not work fast enough to provide any practical protection. Since current follows the path of least resistance, and a 'gap' will always have more resistance than a conductor, it won't be lightning's first choice. By the time the current builds to a level large enough to jump that 'gap', it's already at the other end of that conductor...Zzzz Ouch!
Probably the 'best' lightning arresting scheme is that used by broadcasters. Not the simplest solution, or the cheapest sometimes, but most effective. (Ask 'QRN'.)
