Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Amateur Radio Related > Amateur Radio Antennas
Amateur Callsign Lookup
Enter Callsign:
common mode currents/decoupling
Reply
  #31
Old 10-09-2008, 07:58 PM
Junior Member
Bushmaster is on a distinguished road
Default
Quote:
Originally Posted by W5LZ View Post
Bushmaster,
You're getting into that 'isolate/insulate' thingy here. Electrical tape will insulate the antenna from the mast, but it won't 'isolate' it. Best 'isolator' would be distance to reduce any capacitive/inductive reactance between antenna and mast. Convert that 'distance' to a longer insulator (non conductive mast?). How long? Whatever you can manage without breaking the bank and is still reasonable/practical electrically and mechanically, sort of. After that, you are 'stuck' with whatever it happens to be. While it ~can~ be, it doesn't necessarily have to be a 'big deal', and you won't know till you try it.
Half the fun of it is in the 'doing', not the results...
I came up with a good non-conductive mast. I took a twelve foot 1 7/8 (OD) piece of schedule 80 PVC pipe, and slid a 1 1/2" diameter wooden closet rod dowel rod inside. This made it RIGID. Then I slid the whole kit and kaboodle inside the metal push up pole base. A perfect fit, and a perfect 20 foot mast, that isn't conductive (on the top half).
Viola!
Worldwide Radio Forum
Reply
Bookmarks
Tags
292 radio shop, antenna decoupling
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
