Iam just wondering when setting up your yagi antenna do you set it to True North ?
or Magnetic North?Ihave my yagis in reverse direction -the director pointed south
0 deg-180 degs.I did this because Iam in up of MI.What do you think? Thanks-73
Paul -K8PG CW IS-CW LIVES
O.O.SINCE 1979
__________________ I ONCE WAS A WORK BEAST
NOW I AM A BRAIN MERCHANT
Always use true bearings and never magnetic.All antenna bearings are calculated using true bearings as it gives a more accurate indication of the real world.
__________________ Front/back ratio comes from the antenna. Forward gain comes from the wall socket.
YEP That's How I've Done it For Year's
__________________ Success Seems to be Connected with Action Successful People Keep Moving They Make Mistakes, But They Don't QUIT!
