11-26-2008, 12:18 PM
 | W9WDX Amateur Radio Club Member | | Join Date: May 2008 Location: 35 miles ESE of Indianapolis
I like the Mosley POWER MASTER BEAMS *No Measuring - Pre- Drilled - Color Coded *Heavy Duty Construction *Stainless Steel Hardware *Two Year Warranty "Power-Master" Beams are full-sized arrays, each designed for operation on a single band -- Mosley A-311, eleven meter three element, Mosley A-411, eleven meter four element, Mosley A-511, eleven meter five element. Superlative performance and construction characterizes each beam to insure satisfaction under the most adverse conditions. Antennas are 100% rust proof. Stainless steel hardware, high-impact polystyrene insulators with drawn, seamless, aluminum elements & boom will provide many additional years of trouble-free operation. Low SWR over entire bandwidth. Maximum gain on all bands with an operating capacity well over 1 KW. All "Power-Master" antennas are fed with 52 ohm coax using the famous "Mosley-Match". Mosley Electronics, Inc. 1325 Style Master Drive Union, MO 63084 (636) 583-8595
__________________ Yaesu FT-950 + FT-817 / Kwd TS-450sat
Yaesu FT-450at Mobile
Antennas are 95% of your signal,
"A dime in the antenna is worth a dollar in the transmitter any day" |
