Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Amateur Radio Related > Amateur Radio Antennas
Amateur Callsign Lookup
Enter Callsign:
inverted L antenna for 1431KHz MW band
Reply
LinkBack (1) Thread Tools Display Modes
  1 links from elsewhere to this Post. Click to view. #1
Old 01-10-2009, 05:03 AM
Junior Member
tzitzikas is on a distinguished road
Default inverted L antenna for 1431KHz MW band
hi.
i have a transmitter about 150 watt (output an 813 tube 1400vdc) at 1431khz (salonika greece) and the antenna that i'm using is an inverted L antenna (with a less than 5l/16 length ,about 20m vertical segment and 40m horizontal segment). the coupler that i'm using now is l-type . at http://www.geocities.com/tzitzikas_ee/antenna.gif you can see a schematic of my coupler.
i would like to improve the efficiency of my antenna.
i would like to ask you which inverted L lenght is better for stronger local signals:
1/2, 3/8, 5/16, 5/8 or 1/2 wavelenght? thanks
Worldwide Radio Forum
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://www.worldwidedx.com/amateur-radio-antennas/31923-inverted-l-antenna-1431khz-mw-band.html
Posted By For Type Date Hits
inverted L antenna for 1431KHz MW band - Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF This thread Refback 01-10-2009 06:11 AM 1
Powered by vBulletin®
