Go Back   WorldwideDX Amateur Radio Forums > Amateur Radio Related > Amateur Radio Antennas
Amateur Callsign Lookup
Enter Callsign:
Antenna height help
Reply
  #1
Old 04-12-2009, 06:47 AM
DragoSapien's Avatar
KF5AEJ
DragoSapien is on a distinguished road
Default Antenna height help
In the small town we live in, there is a small airport that is only used for small planes. Three of four I think. Is there a nataniel or state standard on the hight or dose it depend on the airport. I think the county takes care of it. Who exactly do I ask.
Thanks for any help.
  #2
Old 04-12-2009, 08:54 AM
Beetle's Avatar
Senior Member
Beetle is on a distinguished road
Default
You need to read and be familiar with 47 CFR Part 95, which is the FCC rules for CB and other personal radio services. Specifically paragraph 95.408(d):
(d) If your CB station is located near an airport, and if your antenna structure is more than 6.1 meters (20 feet) high, you may have to obey additional restrictions. The highest point of your antenna must not exceed one meter above the airport elevation for every hundred
meters of distance from the nearest point of the nearest airport runway.
Differences in ground elevation between your antenna and the airport runway may complicate this formula. If your CB station is near an airport, you may contact the nearest FCC field office for a worksheet to help you figure the maximum allowable height of your antenna. Consult part 17 of the FCC's Rules for more information.
Warning: Installation and removal of CB station antennas near powerlines is dangerous. For your safety, follow the installation directions included with your antenna.
__________________
If you're like everybody else,
you're about average.
73 de K7KBN
CWO4 USNR RET.
  #3
Old 04-12-2009, 10:45 AM
Moleculo has disabled reputation
Default
The section Beetle quoted applies to CB, not Ham radio.
KF5AEJ is a Ham, so this is what applies to him:
§97.15 Station antenna structures.
(a) Owners of certain antenna structures more than 60.96 meters (200 feet) above ground level at the site or located near or at a public use airport must notify the Federal Aviation Administration and register with the Commission as required by Part 17 of this chapter. (b) Except as otherwise provided herein, a station antenna structure may be erected at heights and dimensions sufficient to accommodate amateur service communications. [State and local regulation of a station antenna structure must not preclude amateur service communications. Rather, it must reasonably accommodate such communications and must constitute the minimum practicable regulation to accomplish the state or local authority's legitimate purpose. See PRB-1, 101 FCC 2d 952 (1985) for details.]
  #4
Old 04-13-2009, 02:30 PM
Beetle's Avatar
Senior Member
Default
Oops! I didn't read the fine print!
That admission made, however ... KF5AEJ needs to read and become familiar with 47 CFR Part 97, rather than Part 95. By signing the license/paperwork, you certify you have a copy or have access to the document via computer.
You don't have to memorize the whole body of the documents, but you have to know where to look up the answers to questions that may come up.
__________________
73 de K7KBN
CWO4 USNR RET.
  #5
Old 04-14-2009, 05:24 AM
hookedon6's Avatar
Senior Member
hookedon6 is on a distinguished road
Default
gee, i have heard that before, but, my copy of 97 doesn't say that in 97.501 (or anywhere else that i have found). am i missing it somewhere?
  #6
Old 04-14-2009, 06:14 AM
KF5AEJ
Default
Thanks everyone for your guidance. I figured if the Hwy. Dept. can have a 200' tall tower just two blocks from me. Then a 30' or even a 50' antenna will be OK.
  #7
Old 04-14-2009, 11:55 AM
WX2MIG's Avatar
Still Alive & Well
WX2MIG is on a distinguished road
Default
I haven't studied every aspect of the rules, but I do recall something about any antenna structure exceeding 200 ft you have to run it past the FAA, and I believe it has to have a flashing red light at the top.....
Again, I'm just going on a few points I retained after scimming through the rules, no doubt I missed a few important points there, and could have it all wrong. None of my antennas exceed 25 ft. so I'm not real concerned about height regulations......
__________________
37OH - SSV - O773H
  #8
Old 04-14-2009, 06:25 PM
Beetle's Avatar
Senior Member
Default
Quote:
I've always thought that was one of the things Moses brought down from the mountain, but I haven't found it.
However, if any licensed ham is found to be in violation of any requirement of Part 97 (or any of the OTHER applicable parts of 47 CFR that apply to general administrative matters and such), I bet "ignorance of the law" wouldn't be much of an excuse.
And by signing the license paperwork, you are certifying that you will abide by the rules. How are you to know what the "rules" are unless you actually have a copy of the current version, either in print or on line?
__________________
73 de K7KBN
CWO4 USNR RET.
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
