hi all,
im considering adding an RF choke to my mobile installation.
many times these are referred to as "choke baluns", but i dont want anyone to be confused about what this is for.
it is for common mode currents; not impedance transformation.
even though my current setup is for
CB, i
am purposely asking these questions in the ham portion of the forum because i believe the hams here have more experience using RF chokes and such.
my questions are:
1. what length of coax will i have to use to form the coil for the choke to work on 11 meters (
cb freqs)? (i will be using LMR-240UF coax)
2. is it better to have more turns on a small diameter coil form, or to have less turns on a larger diameter coil form? (i realize it is a small consideration, but i
am still curious which one is preferable)
3. will it still work if the choke is 4-5 feet away from (below) the feedpoint?
my install consists of a base loaded antenna (wilson 5000) mounted to the center of the roof, a texas star amplifier (DX400) and a radio (PC78xl)
my goal is to reduce the common mode currents i believe are flowing back down my coax and re-radiating inside the car.
i
am open to all input and past experiences regarding RF chokes in mobile environments.
thanks for your time,
