Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Amateur Radio Related > Amateur Radio Antennas
Amateur Callsign Lookup
Enter Callsign:
need advice on how to properly install large boom antenna on roof tower
Reply
LinkBack (1) Thread Tools Display Modes
  1 links from elsewhere to this Post. Click to view. #1
Old 06-06-2009, 08:11 PM
upgrading soon
Maniac373 is an unknown quantity at this point
Default need advice on how to properly install large boom antenna on roof tower
First let me say I am taking my tech exam this coming Saturday (1 week from today).
I have decided that I want to install a glen martin RT-936 (9 foot tall) roof top tower on my 2 story house. I am going to use a T2X tail twister rotor, a 24 foot long aluminum pipe (2" outside diameter / 1/2" wall / 1" inside diameter) for mast.
I am putting up a large 40 foot boom beam antenna, with an omnidirectional antenna above it. I have the instructions on how to reinforce the roof-- so that wont be the problem-- I just need to know the SAFEST way to install the beam up on the mast-- I can get the roof tower mounted, I can get the mast mounted, I can even get the Omnidirectional antenna mounted on the mast... But I am scratching my head on how to get the beam on the mast once the mast is mounted in the rotor, which will be nested inside the roof top tower.
I asked a friend, and he said I should try to get a truck with a cherry picker/ lift bucket, and install the beam that way.
suggestions are welcome.
Thanks
Charlie
Worldwide Radio Forum
  #2
Old 06-06-2009, 09:55 PM
Senior Member
ajm1571 is on a distinguished road
Default
safest way would probably be to use a bucket truck.
just my .02
__________________
Allen
CDX015
2RT015
QS015
015 from Michigan
KD8FXB
Kenwood TS430s Maco 3's, A99, 80-10 balanced wire and a 20m vertical dipole
" LIFE'S A B**CH, DEAL WITH IT"
  #3
Old 06-07-2009, 08:16 AM
Tyrannosaurus Mex
W9WD is an unknown quantity at this point
Default
Yep
Bucket truck.
You'd be surprised how fast the height gets scary.
I think I would build the whole mast/antenna/guys/coax on the ground and then use the bucket truck to lift the whole contraption to the roof and attach it.
Good luck with your test
  #4
Old 06-07-2009, 08:46 AM
Wire Weasel's Avatar
Psycho Twinky
Wire Weasel is an unknown quantity at this point
Default
Hi Maniac,
The 24' mast you're suggesting sounds long. Does it really need to be that long? I know you want "the higher the better", but that will only serve for your vertical. The beam is for DX'ing and the extra height won't make any difference there.
You're going to be a Tech and am getting a beam with a 40' boom? Is that just for 10 meters? That's going to be the biggest 10 meter beam in the world. Sounds like overkill to me.
This rig is going to be a huge wind/weight load. It will not support itself at this length and you'll have to use guy wires.
I would put this monster beam on only 5 feet of mast and you'll probably need a thrust bearing unit above the rotor to support the vertical side-to-side motion. You can install the beam on the mast, and then stick it in the rotor all at once with just the 3 guys picking it up. Put the vertical somewhere else to get it higher, or live with it on the tower at the reduced height.
It doesn't matter how large or heavy duty a mast pipe is, you just don't see long masts supporting large beams. It's not done. It's too unwieldy. Most hams would put a a regular tower, use a thrust bearing above rotor, and probably like a short 5 foot mast for a beam this size.
If you get it up just as you want, oh do come back and post us some pics fer sure.
good luck
__________________
Supplying All Your Wire and Weasel Needs Since 1869 * All Orders Come With A Free Pack Of Vazomyne For Sustained Performance
gal dx 94hp imax .64, gpk / con 4300hp, 102 stainless
  #5
Old 06-07-2009, 11:09 AM
upgrading soon
Default
Im sorry I wasn't clear on this-- OOPS!
The beam will only be 5 feet higher than the roof mounted tower (Glen Martin RT-936/9 feet tall)-- I will be using a T2X tailtwister rotor, and a Jogunn GS-065 heavy duty thrust bearing. The omnidirectional antenna will be mounted on the top of the 24 foot mast. The omnidirectional antenna has radials coming out at a downward angle-- I need the radials to have a good distance between the omni antennas radials and the boom on the horizontal beam. Thats the reason for the 24 foot long mast.
here is a pic of my omnidirectional antenna. (please notice where the mast attaches)
Charlie
  #6
Old 06-07-2009, 12:39 PM
Psycho Twinky
Default
Same problem Charlie. A 24' mast ain't gonna hold itself up + the vetical on top of it. You'll need guy wires under the vertical to hold the thing up. The guy wire connection disk will have to be able to rotate, and you'll have to be able to tie the guy wires off at points that won't interfere with the big beam. There doesn't have to be that much separation between the vertical's radials and the beam. This could be additionally great shortened if you went with an Antron 99 or Imax 2000. The radial kit is not needed at all.
More good luck
__________________
  #7
Old 06-07-2009, 01:08 PM
Tyrannosaurus Mex
Default
Can't you just remove the radials from the omni and use the yagi elements for the ground plane?
That's what I'm going to do
  #8
Old 06-07-2009, 03:37 PM
upgrading soon
Default
Quote:
The Aluminum pipe I am going with is 24 feet long. 2 inch outside diameter, 1/2 inch wall thickness, and 1 inch inside diameter-- the solid mounting bar on the omnidirectional antenna will slide right into the top of the mast. I will just have to run a bolt through the top of the mast to hold the antenna in place.
you still think I need a set of guy wires? Do you think the mast pipe will bend with the omnidirectional antenna pictured up on top?
The radials facing at a downward angle are active-- they help lower the angle of radiation so this 1/4 wave antenna will transmit similar to a 5/8 wave. They cannot be removed, the antenna will not work as it was originally designed.
How far away would you recommend I mount the omnidirectional antenna above the beam?
Charlie
  #9
Old 06-07-2009, 04:11 PM
Psycho Twinky
Default
Hey Charlie, I'll agree with you that 2" alum. pipe with 1/2" wall thickness is going to be strong. But it's going to be heavy too at 24' long. That's a lot of wind load. But you can get away with it by using guys wires.
I still say you don't need that much separation between them and you're going to alot of expense and trouble just to get your vertical up a little higher...
Hey...more power to ya bro
__________________
  #10
Old 06-08-2009, 12:31 AM
Marconi's Avatar
Old Grandpa
Marconi is on a distinguished road
Default
I agree with Wire Weasel, the mast is too long. I'm not even sure the Glenn Martain is rated or will support that big of mast at that length, plus the weight of that hugh beam. The wind load alone will be considerable without all that mast.
You really need to check with Glenn Martain about the 40' beam even with a 5' foot mast. You need to check with your supplier of the Tailtwister and see if it is up to the tast with such a big beam, heavy duty or not.
The Glenn Martain is probably not a good idea, you really need a good strong tower, maybe even free standing type that will take the torque and lateral energy that mother nature will send your way from time to time. The roof of your house was not built to withstand such business.
After you get that stuff up on your roof you will immediately become the cause of every communication and electronic device problem in the neighborhood.
Be safe and keep us posted.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://www.worldwidedx.com/amateur-radio-antennas/34450-need-advice-how-properly-install-large-boom-antenna-roof-tower.html
Posted By For Type Date Hits
Everything about antenna mast pipe - Yahoo! Glue This thread Refback 06-12-2009 10:15 PM 1
Powered by vBulletin®
