Strange antenna phenomenon suggested, anyone ever heard of this...  | |
06-15-2009, 05:38 PM
| | Senior Member | | Join Date: Aug 2008
| | Quote:
Originally Posted by W5LZ Very creative really, not too bad. Hey, at least it's a new one, which ought'a be worth something hadn't it? You gotta admire a mind like that... what else could you do with it?
- 'Doc | Interesting perspective. You are correct. Those minds could be used somewhere for something.
I JUST WISH THEY WOULD STAY AWAY FROM TECHNICAL DISCUSSION FORUMS. |
06-15-2009, 05:43 PM
| | Quote:
Originally Posted by Rob KI6USW To put this BS question back into perspective, one needs to remember what "SWR" is. A ratio of reflected RF back into the finals when transmitting.
Unless a close and very powerful signal is saturating any antenna, it would be a myth to say that skip affects its SWR. WW's answer is most correct - IMO... | To keep it honest SWR is the ratio of minimum to maximum current or voltage at the load end of an R.F. generator.
Reflected power is not entirely absorbed by the final amp. |
06-15-2009, 08:41 PM
| | Senior Member | | Join Date: Mar 2005
| | That was a Good one..
Guess next time i am talking skip...
i will need look at the SWR's...
Ahh....Nope....lol...that was at least a original line os B.S. |
06-16-2009, 12:43 AM
|  | Old Grandpa | | Join Date: Oct 2005 Location: Houston
06-16-2009, 12:54 AM
| | Quote:
Originally Posted by HiDef To keep it honest SWR is the ratio of minimum to maximum current or voltage at the load end of an R.F. generator.
Reflected power is not entirely absorbed by the final amp. | Hey HiDef, you and Rob are taking this BS Joker too seriously. His pay grade is not up to the distinctions you make, and I'm not real sure about Rob either. |
06-18-2009, 01:41 PM
| | Quote:
Originally Posted by Marconi Hey HiDef, you and Rob are taking this BS Joker too seriously. His pay grade is not up to the distinctions you make, and I'm not real sure about Rob either.  |
Maybe. The problem is there are others reading who don't know that. Some people have almost total recall of what they read. Less than correct posts must be repaired otherwise someone will regurgitate it 20 years from now. |
06-18-2009, 02:54 PM
|  | Senior Member | | Join Date: Dec 2008 Location: Silicon Valley CA, Storm Lake IA
| | Quote:
Originally Posted by HiDef Maybe. The problem is there are others reading who don't know that. Some people have almost total recall of what they read. Less than correct posts must be repaired otherwise someone will regurgitate it 20 years from now. | Exactly. Someone will read this thread and see some logic to it.
That was my reason for my reply.
__________________ What gear do I use?
BASE: Icom IC-718 & GAP Titan DX, Yaesu FT-8800R & Diamond X50A, Magnum OmegaForce S45 & IMAX 2000 w/Astatic D104/TUP9.
MOBILE: Galaxy DX99V & Wilson 1000 w/Astatic D104-M2, Yaesu FT-8800R & Diamond NR-770. "...The 444 in San Jose CA; the Central Gold Coast..." |
06-18-2009, 03:01 PM
|  | Senior Member | | Join Date: Dec 2006 Location: RICHMOND VIRGINIA USA
| | ive never herd of such a thing !
could you post a link to this ...... cough informative cough.... thread
hopefully SOMEBODY over there doesnt believe it !
__________________ |
06-18-2009, 03:44 PM
|  | Member | | Join Date: Apr 2009 Location: Clifton, NJ
| | yes i have many of times with the stargun antenna and fat boy antenna's.
water , and ice is the big concern, sometimes bad mount or even bad coax to. |
06-18-2009, 04:32 PM
| | Member | | Join Date: Mar 2009 Location: Northern Shenandoah Valley, VA
| | Quote:
hopefully SOMEBODY over there doesnt believe it !  |
Hey Booty,
Now you know better than to challenge the Professional CB Radio Operator Gods, after all they are the self appointed experts who know far more than anyone else on the planet and can argue down every known proven law of physics ever discovered with their time proven (I saw it on my S-Meter) tests.  .
"DOSY, just like a easy date. Makes you feel good even though she lies to you" |  | | | Thread Tools | | | | Display Modes | Linear Mode |
Posting Rules
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -7. The time now is 10:19 PM. |
