I know this has been asked tons of times,but I'm having a hard time finding help for my situation. Now that I've got my general ticket and my Jeep is taken care of, I plan to start working on my home base station. I live in a townhome that is 2 story, and i cannot install an exterior antenna due to area regulations. Therefore, I'm limited to my attic. Now my attic has plenty of space, so I should be able to install something in there that will work hopefully. I mean, I realize it won't be as good as an antenna on a tower 50' up, but being in the attic of a 2 story building shouldn't be too bad, I hope. That said. I plan to start out with 2M / 70cm as that's what I Have. In September, I
am looking to add an
HF rig. Now, I have about 60
ft of room up there in a E-W direction and maybe 20
ft or so N-S. Height, at the tallest is probably 10', but I need to verify that. I do know at the tallest point, is a window.
That said, can you guys recommend something for me to get started with. I'm completely open to building one (and in fact would like to give it a try). My onlyc concern with building it, is that I don't want to screw up a radio by making a mistake in my antenna construction. I know I could probably just throw a multi-band magnetic antenna on a cookie sheet by the window, but, I"m hoping to be able to do better than that with a dipole or something.
Also, here is the list of what I'm going to get for my Base Station in the way of radios / other equipment:
2m/70cm Radio (to start with)a
HF/6m Radio (later on)
Linear Power Supply
Wattmeter / SWR Meter
Will this get me started?
