Quote:
Originally Posted by TonyV225 |
Well, that is the famous "discone" biconical antenna that was developed, I think, in the 1940's or thereabouts, for wide-band
reception. I recall that it was intended for use in aviation. I put one about 40 feet off the gound
on the roof of my QTH about 20 years ago as an alternative "listening" antenna, and I've tried using it to Xmit on
HF, VHF, and
UHF. In no cases did it perform as well as my "regular" antennas for these bands. It's basically a compromise antenna. I mean, did you really think you could get a small antenna to cover 25MHz to 1.2GHx?
Here are some of the problems: The discone may be "omnidirectional" but has zero gain. It may bave an SWR of <2.5:1 over a wide frequency range, but do does a 50 ohm resistor...SWR is important in keeping your rig's finals happy, but it says nothing about how your signal gets out. Even on VHF and
UHF, where this antenna is supposed to perform best, you will get out better with a properly tuned J-pole or mag-mounted ground plane vertical.
IMHO, the discone is acceptable as a broad-band scanning antenna if it is mounted high enough and in the clear, and if you just can't set up anything else...
