Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Amateur Radio Related > Amateur Radio Antennas
Amateur Callsign Lookup
Enter Callsign:
Could this scanner antenna be a ham antenna ?
Reply
  #1
Old 09-18-2009, 10:40 PM
Train's Avatar
Location: In the Woods where you can bearly get out with the cell .
Train is on a distinguished road
Default Could this scanner antenna be a ham antenna ?
I'm curious if this scanner antenna could be used as a ham antenna ? Magnet-mount mobile scanner antenna - RadioShack.com
Worldwide Radio Forum
  #2
Old 09-18-2009, 11:00 PM
quiksilver's Avatar
quiksilver is on a distinguished road
Default
Radio Shack...................
__________________
http://www.solarcycle24.com/
  #3
Old 09-19-2009, 05:29 AM
Senior Member
Lazarid Anarion is on a distinguished road
Default
Not really sure on that one.Would need to drop by a store and ask someone.
I personally havent seen any ham radio gear of any type...radios and transmitting antennas... in several years around my area,unless they had one sitting on a top shelf gathering dust...really should give em a call and ask
  #4
Old 09-19-2009, 11:07 AM
Beetle's Avatar
Senior Member
Beetle is on a distinguished road
Default
"A ham antenna?".
Well, not for 160 or 80 meters, that's for sure. But try it with low power and see.
__________________
If you're like everybody else,
you're about average.
73 de K7KBN
  #5
Old 09-19-2009, 11:17 AM
Senior Member
SR385 is on a distinguished road
Default
I'd put an analyzer on it first for sure...and I wouldn't bet on it.
A dual-band 2m/440 antenna is easy to find and not a lot of money, I'd just buy one of them...they'll do fine for general scanner use anyway. I ran 2m/440 whips on my scanners long before I was a ham. That would be the better way to go.
Amateur Mobile Antennas
  #6
Old 09-19-2009, 03:08 PM
IMD262's Avatar
Senior Member
IMD262 is on a distinguished road
Default
Quote:
I wouldn't waste the time.
  #7
Old 09-19-2009, 04:33 PM
Train's Avatar
Default
the reason that i asked was i had it for the scanner and was thinking if i could use it to talk on it or it would be better just to listen on it and not hit the power to it ?
  #8
Old 09-19-2009, 06:55 PM
Beetle's Avatar
Senior Member
Default
A scanner antenna is, by definition, a receiving antenna (scanners don't transmit). Therefore, the manufacturer designs and builds them without high voltage insulation and other considerations that a transmitting antenna requires. As suggested earlier, try it with very low power and see if it works (paying attention to the dimensions and how they correlate to wavelength and frequency), or use an antenna analyzer like the MFJ-259/269 to see what you get that way.
Either way, I'd be careful at any power level above a very few watts.
__________________
73 de K7KBN
  #9
Old 09-19-2009, 07:08 PM
ButtFuzz's Avatar
Anti-BS Advocate
ButtFuzz is an unknown quantity at this point
Default It will work fine on 2m and 70cm...
I've used this antenna, same stock number, before... In the actual product instructions that come with the unit it states you may use it on 144-148 MHz and 440MHz UP TO 25 watts.
Unfortunately, it would appear one cannot download the actual owner's manual from Radio Shack product support at this time.
I have used it on these two bands without incident, following the recommended power maximums.
The magnet is not-so-strong, however, so make sure you affix it to a good piece of steel and keep it under 80 mph.
And for those who just bad mouth radio shack for bad-mouthin's sake, please examine the country of origin of most of your beloved ham radio products... Japan, Korea, Taiwan, China. Same place this antenna is made, amigos.
__________________
ButtFuzz in the Mobile
KG4ZPN
  #10
Old 09-19-2009, 07:17 PM
Train's Avatar
Default
BUTTFUZZ Thanks . All I am going to run is 5 watts and VX-8R should be in Monday according to UPS and my license well maybe next friday on the database .
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
1/4 wave groundplane & end fed verticals - time for some FACTS moleculo CB Antennas 31 03-30-2009 12:51 PM
Super C antenna...this is really neat moleculo Amateur Radio Antennas 8 12-10-2008 10:35 AM
baluns towernewbie Amateur Radio Antennas 16 03-02-2008 05:11 AM
Long overdue antenna review -- And thief info for San Diego Toll_Free A1 Antennas 1 08-02-2006 05:50 PM
Powered by vBulletin®
