Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Amateur Radio Related > Amateur Radio Antennas
Amateur Callsign Lookup
Enter Callsign:
My Lightning 6 Quad antenna
Reply
  #11
Old 09-23-2009, 05:04 AM
Drifter's Avatar
Senior Member
Location: Under a coconut tree in the Carribbean sipping on white rum and coke!!!
Drifter is on a distinguished road
Default
Quote:
Originally Posted by Marconi View Post
Great setup Drifter and looks even better. Can you confirm for me about the positions of the ver/hor feed points? The typical quad has the vertical fed at the 3:00 or 9:00 and the horizontal usually at the 6 o'clock position, but I think it is the opposite with the L6. I have an idea why that is, but I would like your opinion and if you found that confusing at first look? I have never owned a Signal Engineering quad, but would love to play a tune on that one.
How say you?
Give us some words about your success at tuning this monster and how she performs even considering conditions may not be the best right now.
Thanks for your input.
Marconi
Hello, Mine has it's horizontal at 3 o clock and vertical at 6 o clock.... She has been up three years now first as the Lightning 4+. which worked great as a 4 but I wanted more so I bought the upgrade kit which stretched the boom and added two more directors. As a 4 element she was fairly easy to tune.. When I upgraded I had some interference issues from my kids swing set and fort and fence and my neighbor's car parked on the other side of the fence. When I fold the tower over the antenna gets very close to those items. A lot of trial and error and cranking up and down till I got the numbers I wanted on the MFJ. I am scared to make any changes but I have to install upgraded coax and the upgraded feed system from Signal Engineering to accomodate more output.
The Quad is currently being fed with LMR 400uf soon to be upgraded to LMR 600UF coax. The 2meter has 213 coax feeding it.
__________________
Yaesu 101E
Signal Engineering lightning 6 quad Antenna on a 60FT crank up tower.
Worldwide Radio Forum
  #12
Old 09-23-2009, 05:13 AM
Drifter's Avatar
Senior Member
Default
Quote:
Originally Posted by HiDef View Post
Nice tower and antenna. Looks like an old Tristao or an earlier U.S. Tower.
When you put that quad exactly 90 degrees away from a signal is the rejection really good?
Next project could be to put a bunch of 2 meter quad elements on the same boom
Yes HiDef You have a sharp eye and very knowledgeable. The tower is a Tristao.. and yes the antenna is very directional and the rejection is awesome.
__________________
Yaesu 101E
  #13
Old 09-23-2009, 05:18 AM
Drifter's Avatar
Senior Member
Default
Quote:
Originally Posted by unit_399 View Post
Drifter -
Your pictures promote maximum jealousy !!!
- unit 399
Don't mean to do that. lol I just want to share. I like to look at great radio setups too.
__________________
Yaesu 101E
  #14
Old 09-23-2009, 03:57 PM
wambulance is on a distinguished road
Default
Wow! That is sexy!
  #15
Old 09-23-2009, 06:41 PM
Old Grandpa
Marconi is on a distinguished road
Default
Quote:
Originally Posted by KJ4BAE View Post
I just put up a super hawk, the 2 element signal engineering antenna and you are right the feeding is opposite of what it should be. I put this thing together and i still cant figure out why it is like this. It is really confusing but the antenna works very well.
Thanks KJ4BAE, IMO the difference is due to the SE being a voltage fed antenna where the wire is continuous while the traditional quads are current fed and have the resonant wire joined together at an insulator. Your SuperHawk tuner is a bit different in design compared to Drifter’s L4+ or L6, because your SH’s boom is not long enough to appear as a resonant ground element for the feeder to work against, so SE adds this floating ground side wire parallel to the open ended feeder. IMO, this is a very efficient feeder that transitions the impedance very smoothly from the coax end directly into the radiator---transforming the high impedance radiator to that of the feed line, while this is basically end feeding a resonant ½ wave element. The other half of the quad also contributes to the radiation of any quad design, but that is difficult for me to describe.
Quote:
Originally Posted by Drifter View Post
Hello, Mine has it's horizontal at 3 o clock and vertical at 6 o clock.... She has been up three years now first as the Lightning 4+. which worked great as a 4 but I wanted more so I bought the upgrade kit which stretched the boom and added two more directors. As a 4 element she was fairly easy to tune.. When I upgraded I had some interference issues from my kids swing set and fort and fence and my neighbor's car parked on the other side of the fence. When I fold the tower over the antenna gets very close to those items. A lot of trial and error and cranking up and down till I got the numbers I wanted on the MFJ. I am scared to make any changes but I have to install upgraded coax and the upgraded feed system from Signal Engineering to accomodate more output. The Quad is currently being fed with LMR 400uf soon to be upgraded to LMR 600UF coax. The 2meter has 213 coax feeding it.
Thanks for the confirmation Drifter. I believe you when you describe the interference issues you noticed in your yard. I tried to install my Long John 5 element at my location and I was never able to get a reasonable tune even tuning about 25’ high on a 18’ roof deck on my home. The antenna was overly sensitive to everything within 40’ - 50’ feet. Maybe if I could have raised it up to 40’ feet or more it would have worked fine. I ended up putting my 4 element back up and did not have the problem.
Can you describe for us what the new power upgrade is? This must be something new from SE.
  #16
Old 09-26-2009, 03:08 AM
Junior Member
chris.s is on a distinguished road
Default Nice quad
Hi Drifter,the set-up looks great,I have had several of Anthony's quads up,started with the Superhawk than went to the 4 element White Lightning,he did not have the 4 plus at the time so after I sold the 4 I bought the 6,I had the cross peices welded to the boom and changed some of the hardware out for stainless stuff it was up around 55ft and worked great,I used to like it when you could DX when the other guys were'nt hearing anything at the time,I had it up for about 1yr the mother nature blessed us with an ice storm and that took care of quad,so know an A-99 cut for 10 meters and a Par loop for 6 are on the tower,good luck with the quad.
73s
Chris.s
  #17
Old 10-05-2009, 03:54 PM
Junior Member
mr.trashman is on a distinguished road
Default
this is a great looking beam im in the market for one as well ,love the photos u took of the tower and beams , hope u are having a great time with them . hope to have mine soon for my birthday in december my treat to myself .by the way do they work well at 50-feet in the air need a great answer for this height im sitting at a high elevation already above the trees where i live in texas. thanks mr.trashman in txs
  #18
Old 10-05-2009, 07:16 PM
Drifter's Avatar
Senior Member
Default
Quote:
Yes it will work at 50' Read here
SIGNAL ENGINEERING - The Evolution of High Performance CB Antennas
__________________
Yaesu 101E
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
your favorite CB myth , lies and legends . BOOTY MONSTER General CB Services Discussion 87 02-02-2010 05:47 AM
1/4 wave groundplane & end fed verticals - time for some FACTS moleculo CB Antennas 31 03-30-2009 11:51 AM
Super C antenna...this is really neat moleculo Amateur Radio Antennas 8 12-10-2008 09:35 AM
baluns towernewbie Amateur Radio Antennas 16 03-02-2008 04:11 AM
Powered by vBulletin®
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
