I know this will open up some controversy however, I
am writing from personal experience. I've owned both the Moonraker IV and the Shooting Star beams. The Shooting Star is the better antenna for two reasons. If you have ever tried to obtain a perfect VSWR on the vertical side of a Moonaraker, this is no easy task. The vertical driven element on this antenna is highly effected by the location of the mast and the coax. The antenna places the vertical driven element too close to the mast bracket and coax. This causes them to radiate and produce reflected power that can change with the direction of the antenna.
The second reason I do not like the Moonraker is the mechanical construction. The aluminum hubs either turn from not being tight enough or crack from being too tight. The fragile little fingers on the tips of the elements aren't much better. They are the first parts to bend down or break off. After spending over a week 60 feet up the tower working on the Moonraker I gave it away for free and purchased the Shooting Star. In one afternoon I had it together and tuned perfectly. The muffler clamp style U-bolts used on the Shooting Star combined with improved element spacing make it the clear winner in my book.
