Can a mobile antenna be used mounted on something other than a vehicle? Yes. Basically, you only have to provide the other half of that antenna like a vehicle's body does. Sounds simple till you get down to the nutz'n'boltz of it, then it get's kind'a more difficult.
That mobile antenna mount is the 'handle' the vehicle uses to hold onto the antenna. So if you want to hold that antenna you have to figure out a 'handle' for you to use to hold on to it. Same for in/on a house, tree, music stand, whatever, you need a 'handle' and the other half of the antenna. You can adapt almost anything if you have enough imagination. That antenna (and radio) doesn't have a lot of imagination so you have to get things sort of right for it, you know?
Since it's a tri-band antenna, the absolute minimum to use as the 'other half' is a counterpoise that's 'cut' for th lowest frequency of use. Just like that 'rat-tail' antenna thingy for your
HT, except longer. If you want to do that for all three bands, fine and dandy, or just make do with that longer one (same thing that happens when it's on a vehicle).
Is it 'dead-nutz-easy'? Nope, but it certainly isn't impossible either.
