Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Amateur Radio Related > Amateur Radio Antennas
Amateur Callsign Lookup
Enter Callsign:
Have Radio, No QSO
Reply
  #21
Old 10-27-2009, 06:26 PM
Senior Member
moleculo has disabled reputation
Default
Quote:
Originally Posted by KB1SYV View Post
I can buy ladderline if it will get me better result's. What could I use as posts to wrap the wire around? I'm probably going to have to do a horizontal. Do I need to wind wire more than once? What kind of gauge wire that will hold up to ice and snow. I have an ldg at897 autotuner without a balun, will I be able to direct feed the antenna to the ladder line, to the tuner? Any suggestion on how I would ground this as well?
Jethro
You can use just about anything as posts; the key is to make sure it can stand up to the weather. Even a wooden broom handle can work if you can weatherize it. You should be able to find some TV antenna style masts at a local hardware store and figure out a way to mount them on the roof somehow. You'll at least need one to support the center of the dipole and you may need one for each end. You need some insulators of some type, as well. You can make your own out of something or buy them. Here's a little picture:
You can see in this picture coax is used. If you use coax, you can run the feedline next to anything practically. If you use ladder line, you have to be a bit more careful. You certainly don't want to wrap it around masts! Most dipole calculators assume 14 gauge wire, but any size can be used. 14 gauge will probably handle whatever weather you can throw at it. It doesn't matter how many wraps you use to tie it off to itself...just enough that it is secure. On the outside of the insulators you can use guy wire, rope, whatever you have to work with.
Unless that autotuner has terminals for parallel feedline, you will need a balun if that is the type of feedline you want to use. They're not expensive for a 100 watt rig.
Worldwide Radio Forum
  #22
Old 10-27-2009, 06:28 PM
Senior Member
Default
Here's a link for building a simple doublet (That's what a dipole is called with parallel feedline)
The All Band HF Doublet - 80 thru 10 Meter Ladder Line Multiband Antenna
  #23
Old 10-27-2009, 06:31 PM
KB1SYV's Avatar
Old School Newbie
KB1SYV is on a distinguished road
Default
Any suggestions for suitable grounding, or is it necessary?
__________________
"Is this what you meant by a sudden disturbance."
Jeffrey W
(Jethro)
KB1SYV
SKCC #5868
European PSK Club (EPC) #8624
BARTG #8264
NAQCC #3891
30 Meter Digital Group #2758
The Feld Hell Club #2414
Digital Modes Club #2481
Flying Pigs QRP Club International #2292
  #24
Old 10-28-2009, 03:23 PM
Senior Member
Default
It's not necessary to make that type of antenna work. You should try to do some type of station grounding at the rig, but that can be difficult to accomplish if you're in an apartment and not on the first floor. Try it without and see what happens...
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
HELP! Service Manual For Cobra 2000GTL?? Rob KI6USW Tech, & Repair 13 08-22-2009 04:47 PM
Super Swing and That Channel 6 Sound ButtFuzz RADIO AND RADIO RELATED MODIFICATIONS 2 06-10-2009 09:45 PM
The ARRL Letter Vol. 26, No. 49 December 14, 2007 AudioShockwav FCC & ARRL Activity 0 12-14-2007 09:19 PM
The ARRL Letter Vol. 26, No. 48 December 7, 2007 AudioShockwav FCC & ARRL Activity 0 12-10-2007 06:34 PM
Marine Radio Rules Charger383 Scanning & Shortwave Listening 0 07-07-2002 08:12 PM
Powered by vBulletin®
