Have Radio, No QSO  | |
10-23-2009, 06:04 PM
|  | Old School Newbie | | Join Date: Sep 2009 Location: On me boat!
| | Have Radio, No QSO Hello Everyone,
I finally got my rig and got an excellent deal in the process. I am the proud owner of a Yaesu FT-897D w/FP-30 internal PS, LDG AT-897, and 5 vertical antenna's for 40,20,17,15, and 10 m. All for $1050.00. Now that's the good news. The bad news is I've been scanning the 40 meter band for about 3 hours now and I can barely hear anyone, except for one and I found out by his callsign that he is the next town over. I have yet to have anyone answer my call. My feeling is that my transmit is not meeting the range of my recieve, by a longshot. I'm pretty sure my issue is the fact that I live in an apartment and I put the 40 meter antenna out my one window. The possible problem is that the antenna doesn't clear the surrounding 4 walls. I live on the 3rd floor, but the top of the building extends further up from my floor. I don't have access to the roof so I can't move the antenna up there. Does anyone have any ideas? Are my assumptions correct or is it something else? Would putting an antenna "in" my apartment give me a better outcome?
Thanks in advance.
Jethro
__________________ "Is this what you meant by a sudden disturbance."
Jeffrey W
(Jethro)
KB1SYV
SKCC #5868
European PSK Club (EPC) #8624
BARTG #8264
NAQCC #3891
30 Meter Digital Group #2758
The Feld Hell Club #2414
Digital Modes Club #2481
Flying Pigs QRP Club International #2292 |
10-23-2009, 07:00 PM
|  | Senior Member | | Join Date: Dec 2008 Location: Silicon Valley CA, Storm Lake IA
| | Great deal.
Antennas are the most important part of the radio system. Getting them have all the performance they can produce will probably be your biggest challenge - especially in an apartment. That situation may prove to be very difficult.
If it is agreeable to the apartment mgr; maybe a single antenna in the form of a 10-40 meter dipole may be best. Apartments are really very strict about this kind of thing - I hope the best for you in this given situation.
Having them indoors can work; but chances are - it will hinder performance even more...
__________________ What gear do I use?
BASE: Icom IC-718 & GAP Titan DX, Yaesu FT-8800R & Diamond X50A, Magnum OmegaForce S45 & IMAX 2000 w/Astatic D104/TUP9.
MOBILE: Galaxy DX99V & Wilson 1000 w/Astatic D104-M2, Yaesu FT-8800R & Diamond NR-770. "...The 444 in San Jose CA; the Central Gold Coast..." |
10-23-2009, 10:11 PM
| | Senior Member | | Join Date: Aug 2009
| | Get out of the apt.
Try some field work to see if it is the building or the equipment. |
10-24-2009, 05:19 AM
|  | Radio Operator | | Join Date: Sep 2008 Location: North Carolina
| | Have you checked SWR?
Feedline for open or short?
Power output from the rig? |
10-24-2009, 08:31 AM
| | I have already contacted Wales outside the apartment as a demo. I just bought the radio and set it up, so I don't have a way to test anything yet.
73,
Jethro
Jeffrey W
(Jethro)
KB1SYV
SKCC #5868
BARTG #8264
NAQCC #3891
10-26-2009, 04:24 PM
| | Senior Member | | Join Date: Apr 2002
| | You mentioned that they're vertical antennas. I'm assuming that you are using some type of counterpoise? What can you tell us about the antennas? Of course it doesn't help that propagation has been lousy... |
10-26-2009, 04:37 PM
| | I'm positive its the location. My window is located on one of the walls of a stone box for lack of a better term. The roofline is ten ft above my window. The only open air is above. I'm not sure what to do. But one thing is for sure, the answer isn't to move. That's the lazy answer.
73,
Jethro
Jeffrey W
(Jethro)
KB1SYV
SKCC #5868
BARTG #8264
NAQCC #3891
10-26-2009, 04:55 PM
| | A lot of people use indoor dipoles, loops, and other antennas in apartments. It's by no means ideal, but it is doable. |
10-26-2009, 04:59 PM
| | I've been trying to use an 8ft 20m and a 40m hamstick inside but I get nothing. I ran a 18 AWG jacketed wire from the back of the radio out my window to 15 ft below, but I'm not sure what else to do to get any reception from indoors.
Jeffrey W
(Jethro)
KB1SYV
SKCC #5868
BARTG #8264
NAQCC #3891
10-27-2009, 10:06 AM
| | Quote:
Originally Posted by KB1SYV I've been trying to use an 8ft 20m and a 40m hamstick inside but I get nothing. I ran a 18 AWG jacketed wire from the back of the radio out my window to 15 ft below, but I'm not sure what else to do to get any reception from indoors. |
How do you have those hamsticks mounted? Are you able to increase the amount of ground plane underneath of them? |  | | | Thread Tools | | | | Display Modes | Linear Mode |
Posting Rules
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -7. The time now is 11:36 PM. |
