Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Amateur Radio Related > Amateur Radio Antennas
Amateur Callsign Lookup
Enter Callsign:
Stacking Antenna's
Reply
  #1
Old 10-26-2009, 02:34 PM
loboman's Avatar
Junior Member
loboman is on a distinguished road
Default Stacking Antenna's
What are the issues with stacking two antenna's on the same mast?
I have a scanner antenna on a mast on my garage - Can I put a CB antenna above the scanner antenna?
Thanks for the help.
__________________
AKA - N7MSK
Worldwide Radio Forum
  #2
Old 10-26-2009, 03:08 PM
Supporting Member
W5LZ is an unknown quantity at this point
Default
The biggest 'effect' is how they can interact. When that interaction isn't really objectionable, then it's fine.
I think I'd put that scanner antenna on top. They are usually fairly small/light, and height always helps. How much higher? Beats me, whatever you can manage. Then remember that since that scanner antenna is close to an RF source, the scanner is going to 'see' that source of RF VERY well! Hope you don't have any CB channels plugged into it, sort of...
  #3
Old 10-30-2009, 10:44 PM
Junior Member
gogo_gadgit is on a distinguished road
Default
I have a scanner antenna on the same mass with my cb ant above it. Some times the scanner locks up, and other times it doesn't. I find other scanners don't lock up at all, while my bear cat 200xlt locks up on ever channel.
However I must admit your antennas will probably be much farther apart then mine, at the closest point there is probably do more then 2 feet between the elements of each on the antennas, so I think you will be fine
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Circular Polarized Antenna Pushrod CB Antennas 28 03-20-2008 01:30 PM
baluns towernewbie Amateur Radio Antennas 16 03-02-2008 05:11 AM
Safety Standard for CB Base Antennas Master Chief CB Antennas 0 09-04-2007 10:09 AM
Antennas and the lies we tell... hossless CB Antennas 1 02-25-2005 10:21 PM
Powered by vBulletin®
