Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Amateur Radio Related > Amateur Radio Antennas
Amateur Callsign Lookup
Enter Callsign:
full wave 10m antenna, will this work?
Reply
  #11
Old 11-02-2009, 03:00 PM
Junior Member
ShadowecR is on a distinguished road
Default
I've gathered some things together to make it but if this kind of design is known not to work, i'd rather try something else. any other thoughts before I start? Thanks again everyone.
Worldwide Radio Forum
  #12
Old 11-02-2009, 05:20 PM
Senior Member
CDX-007 is on a distinguished road
Arrow Full Wave Loop, One Half Wave Tall
I built one many centuries ago and had to feed it at the side-center with 75ohm RG-11 cut to 1/4 wave length multiplied by the velocity factor, which in this case was 66% so it ended up ~5' 7" long (for 28.4mHz centering) and which matched it to the 50ohm coax nicely.
It was a good performing antenna but a bit challenging to get the feedline to attach from perpendicular to the antenna.
I kept the inherent potential impedance at a factor of 10+ above 50ohms by separating the wire 1.5 inches as it traveled up & back down the outside of the 20' x 1.5" fiberglass rod.
Handled full legal power @ 1.2:1 vswr until a falling tree branch had it for lunch.
Let us know the outcome.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
your favorite CB myth , lies and legends . BOOTY MONSTER General CB Services Discussion 74 10-23-2009 07:07 PM
Full wave antennas for CB linearone CB Antennas 34 04-18-2009 12:55 PM
The 5/8 and .64 debate! Master Chief CB Antennas 47 08-28-2006 08:45 PM
Jays I-10K Antenna Feedback RollingRadios A1 Antennas 29 10-02-2004 08:52 AM
Powered by vBulletin®
