Go Back   WorldwideDX Amateur Radio Forums > Amateur Radio Related > Amateur Radio Antennas
Amateur Callsign Lookup
Enter Callsign:
7/8 wave 2 meter mobile
Reply
  #1
Old 01-07-2010, 07:01 PM
towerdog's Avatar
one-niner-seven
towerdog is on a distinguished road
Default 7/8 wave 2 meter mobile
who makes it and what is it, a 7/8 wave antenna for 2m (and 440?) I suspect its a 5/8 wave over 1/4 wave. I have been told this would be a better mobile antenna than a 5/8.
  #2
Old 01-07-2010, 09:32 PM
Senior Member
bob85 is on a distinguished road
Default
towerdog, if you mean the 7/8wave shuntfed whips that look like an old smc oscar foldover cb antenna i cant remember who made them, i have seen them with different brandnames on the same antenna,
they are a 7/8wave single element antenna,
i tried a ham buddies 7/8wave that he raved about against my identical looking but shorter 5/8wave and got more flutter on my mobile signal with the 7/8wave,
if you mean a 5/8wave over 1/4wave colinear thats a different ballgame, the radiation angle can be manipulated by the designer to give a lower or higher radiation angle and higher gain than a single element antenna at the expense of vertical beamwidth, the result may or may not suite your mobile needs
__________________
tom bearden taught me that quantum entanglement allows thought to travell faster than the speed of light, this explains why at first you can think somebody is smart but if you wait a while you will see they are not very bright at all.
  #3
Old 01-08-2010, 04:37 AM
Senior Moment
Wire Weasel is on a distinguished road
Default
Not sure about 7/8 but Hustler makes what I believe is a colinear 5/8 (two 5/8's put together one of top of the other) Any Hustler dealer should have them. Ham Radio Outlet sells them.
The 3/8 x 24 threaded is model # CG-144
Trunk Lid Mount is # CGT-144
I've used one in the past. Work well. Best if you can locate in the free and clear.
Good luck
  #4
Old 01-08-2010, 04:48 AM
IMD262's Avatar
Senior Member
IMD262 is on a distinguished road
Default
MFJ Enterprises Inc.
  #5
Old 01-08-2010, 07:08 AM
towerdog's Avatar
one-niner-seven
Default
Quote:
Originally Posted by IMD262 View Post
thats it! what I was looking for, thanks. I beleve flutter can be caused by the whip whipping around too much in the wind, I heard you might have radiation pattern issues from insufficient ground plane from a 7/8 also but I will read up on it, and check the reviews out.
Good luck
thats model, CG-144 is a 5/8 over a 1/4. I cant find a colinear for mobile but did find this stacked 5/8 colinear for base application. Base Model G7-144 with 7dB gain. If that 7dB is true, thats more than some directional antenna, pretty cool, I might try to build such a thing. Is co-linear the same as co-phased?
  #6
Old 01-08-2010, 07:39 AM
Senior Member
SR385 is on a distinguished road
Default
Keep in mind, the more gain, the 'flatter' the radiation pattern gets....it gets narrow as a razor. On flat, open ground or slight elevation advantage, this can be great. In varied terrain with rolling hills and buildings, this can actually hurt you vs a much higher angle of radiation on a no or low gain antenna.
  #7
Old 01-08-2010, 08:02 AM
Transducer Fanatic
CDX-007 is on a distinguished road
Default
I and two friends both tried the Hustler 144 and never got performance as good as the base loaded 5/8 in test after test. Mine is relegated to the storage room.
  #8
Old 01-08-2010, 01:20 PM
Captain Kilowatt's Avatar
Professional Amateur
Captain Kilowatt will become famous soon enough
Default
Quote:
EXACTLY! Gain is not everything. I used to run a Diamond SG-2000HD antenna which is also a 7/8 wave. It was great for simplex mobile-mobile but was almost always beaten by a simple 1/2 or even 1/4 wave antenna when working repeaters high on the hilltops from the valley floor. I later switched to a Comet CA-2X4SR because of that and also the need for wider bandwidth. For somewhere on the great plains a 7/8 wave antenna is great. As for the "picket fencing" , or flutter, I actually had less with the 7/8 wave antenna then any other type.
__________________
There are 10 kinds of people in this world. Those that understand binary and those that don't.
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
your favorite CB myth , lies and legends . BOOTY MONSTER General CB Services Discussion 190 02-15-2012 07:54 PM
1/4 wave groundplane & end fed verticals - time for some FACTS Moleculo CB Antennas 31 03-30-2009 11:51 AM
Palstar WM150 Mobile swr/what meter ANYGOOD ? subs757 Meters, Mics & Other Accessories 5 02-17-2005 11:51 AM
Powered by vBulletin®
