Go Back   WorldwideDX Amateur Radio Forums > Amateur Radio Related > Amateur Radio Antennas
Amateur Callsign Lookup
Enter Callsign:
AZ EL Rotator
Reply
  #1
Old 07-03-2010, 01:50 PM
W1MSG's Avatar
Now W1MSG
W1MSG is on a distinguished road
Default AZ EL Rotator
I would like to put up a dual band beam for doing Satellites with a AZ / EL Rotator so I can do it all from the house. Anyone have any suggestions ? I would even go with a 2 meter and 70cm beam if needed...
__________________
Craig, W1MSG
IC-9100 / ID-51, Commander HF-2500
  #2
Old 07-03-2010, 03:22 PM
Senior Member
Hutch is on a distinguished road
Default
There's really only a few to choose from Yaesu, Alpha-Spid, KLM, Primesat and M2, I think there are a couple more, most companies only make one or two models that have Az and El.
You might want to check out what rotors your tracking software supports. I use MacDoppler and it will support most rotors on the market and will control many different radios too.
  #3
Old 07-06-2010, 01:58 PM
Moleculo has disabled reputation
Default
I've only ever seen the Yaesu in person. They're supposed to be well made. Let us know what you choose and how it works...some pics would be cool too!
  #4
Old 07-06-2010, 02:56 PM
W1MSG's Avatar
Now W1MSG
Default
Well I am thinking that I might just go with a plain rotator and set the antenna at 20 degrees elevation, I have heard from a few people who are doing this with great results. Of course they are using much larger beams. As soon as I make up my mind on a HF Rig I'll set things in motion for the adjustable antenna. Probably looking at the FT-857D as a base system in the house. Looks like the best bang for the buck and I really want to be ableto work the sats with it.
__________________
Craig, W1MSG
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ameritron RCS-8V coax switch & AR-35 Rotator additions to the shack Moleculo Product Reviews 27 03-22-2012 08:16 PM
AlphaSpid Rotators Captain Kilowatt Amateur Radio Antennas 14 03-18-2010 08:52 AM
Antenna Rotator Power Cable vitvoo1 Amateur Radio Antennas 2 07-10-2008 07:55 PM
Antenna Rotator Whisky65 General CB Services Discussion 3 05-28-2005 05:18 AM
Powered by vBulletin®
