09-30-2010, 03:35 AM
 | Professional Amateur | | Join Date: Apr 2005 Location: Nova Scotia,Canada
That site in the original post is the only one I have seen that states 9% shortening. Everything else I have ever seen or heard states about 5% which is what I believe to be true unless you are using a really fat conductor on VHF/ UHF frequencies. The reason is partly due to the velocity factor of the element material and mostley due to something called "antenna end effect" which is a small capacitance that is formed by the antenna elements in air and has the effect of "detuning" the antenna. In order to compensate the antenna length must be changed slightly.
__________________  |
