Go Back   WorldwideDX Amateur Radio Forums > Amateur Radio Related > Amateur Radio Antennas
Amateur Callsign Lookup
Enter Callsign:
Advice for Wire Reciving SWL Antenna
Reply
  #1
Old 11-12-2010, 10:54 AM
Junior Member
bludytiger is on a distinguished road
Default Advice for Wire Reciving SWL Antenna
I am planing on putting up an outdoor wire antenna, but I am a little undecided on what antenna I should make. Normally I would try experimenting with a few and choose the best, however I am running out of good weather and would like to get one up before snowfall.
I am planing on using it for receive only on shortwave bands. I live out of town and have a fair amount of space to put one up. I don't have a tower yet and am planing on using trees. I have one really big tree that is taller then anything around that I can use. Most other trees are not taller then the house.
At first I was going to put up a 100' long wire, but I would have to put it lower on my big tree in order to keep it horizontal to the ground. I thought however that maybe I should do an inverted V since I have one very high point but I don't know if they are better then long wire or not. I also noticed that there are multi-band long wire and multi-band inverted V. Do these really help over single wire?
Building them isn't much of a problem for me since I enjoy building my own stuff. I currently have 100' of shielded 12 gauge wire, PVC conduit for insulators, and TV coax for feed line. The only materials I really can't change is my feed line since I don't have access to 60ohm coax right now. Will the outer layer of the coax diminish performance on a dipole? If that is the case, should I go with a single wire fed long wire?
  #2
Old 11-12-2010, 12:19 PM
Senior Member
office888 is on a distinguished road
Default
Make a beverage antenna if you've got a lot of space.
__________________
KD8NPB
Catch me on the K8BRC 147.360 repeater!
  #3
Old 11-12-2010, 12:50 PM
Junior Member
Default
I never herd of a beverage antenna before but just looked it up. That is a really nice idea, however might be a bit bigger then I want to build at the moment. That and I don't know if my trees are up to supporting that amount of wire. That is possibly a good project for me in spring.
  #4
Old 11-12-2010, 12:57 PM
TonyV225's Avatar
TonyV225 is on a distinguished road
Default
a simple 80 mmeter dipole would work you can save room and use it in an inverted V configuration. I use my for transmit and then at night use it on shortwave once and a while on AM 1100 for Coast To Coast Radio. It works just fine
__________________
""""was not thinking of a cber sat with his makita screwdriver winding round the presets untill his meter said s9+60db from a guy on a handheld 15 miles away""""
  #5
Old 11-12-2010, 01:51 PM
sp5it's Avatar
Master of puppets
sp5it is on a distinguished road
Default
Shortwave you mean BC or amateur bands?
I would recommend a loop antenna, K9AY.
Take a look at this site: Antenna Special -- on hard-core-dx.com
it can give some ideas.
Mike
__________________
My pile-up breaker
  #6
Old 11-12-2010, 02:09 PM
wavrider is on a distinguished road
Default
As stated before it all depends what you are wanting to listen to.
If it is going to be an all around BC and SW amateur bands then by all means run you a BIG dipole as long as you can get it on each side.
If you want to go even further attach a small antenna coupler to the antenna in the shack and then turn your reciever on to whatever frequency you want to tune the antenna coupler for the strongest receive signal, you will get some good weak signal reception this way.
Loop antennas work good, they have their drawbacks with nulls, as do dipoles if erected at a halfwave length in height, if you are targeting BC stations you will not have that problem.
  #7
Old 11-12-2010, 02:16 PM
TonyV225's Avatar
Default
So all in all it boils down to what you are going to do with this antenna once you know that then building or buying one should be the easy part.
__________________
  #8
Senior Member
bioman is on a distinguished road
Default
BIG di-pole if you have the room as stated a "coupler" or "trimmer" will work wonders.....
if you dont have enough room to put up 250+ feet of wire a G5RV works SURPRISINGLY well for SWL
__________________
cdx-1557 reading pennsylvania keystone state
REAL radios glow in the dark
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Firestick IBA-5 Apartment Antenna Robb CB Antennas 3 09-20-2010 08:05 AM
isolation from mast Splash1 CB Antennas 71 03-17-2010 09:23 PM
Used CB Radio: How to Buy-Part 1 Robb General CB Services Discussion 5 11-30-2009 06:50 PM
Powered by vBulletin®
