Go Back   WorldwideDX Amateur Radio Forums > Amateur Radio Related > Amateur Radio Antennas
Amateur Callsign Lookup
Enter Callsign:
MFJ 1622 Apartment Antenna?
Reply
  #1
Old 11-30-2010, 12:11 PM
ZuMBLe is on a distinguished road
Default MFJ 1622 Apartment Antenna?
I've been playing with the idea of building a 11/10 meter loop antenna for my 1st floor apt but I'm becoming quite discouraged. I installed a SWL antenna around my bedroom by the window and can barely hear any 11 meter stations. Which brings me to the MFJ 1622. Anyone have any experience with these? I'd be running a LDG Z100 Plus behind it.
MFJ Enterprises Inc.
http://www.mfjenterprises.com/man/pdf/MFJ-1622.pdf
  #2
Old 11-30-2010, 12:35 PM
Crotchety Old Bastard
W5LZ is on a distinguished road
Default
I don't have one, but I've made a few of them. If you do the 'tuning' right, you won't need a tuner. Basically find a tap for 10 meters and one for 11 meters. How well does it work? Needless to say it won't be 'perfect', but it should at least match a mobile antenna of the same length. It should be marginally better than the indoor antennas you have, maybe.
  #3
Old 11-30-2010, 12:43 PM
Default
Good info, as always. It's not easy being a radio enthusiast in NYC.
I figured I'd run the tuner behind the antenna to try to get the best match possible after tuning.
Quote:
  #4
Old 11-30-2010, 12:56 PM
TonyV225's Avatar
TonyV225 is on a distinguished road
Default
Workman BS-1 Indoor Dipole Base Antenna for HAM Radios - eBay (item 220696012301 end time Dec-12-10 13:49:18 PST)
Workman BS-1 HAM - Palco Electronics
__________________
""""was not thinking of a cber sat with his makita screwdriver winding round the presets untill his meter said s9+60db from a guy on a handheld 15 miles away""""
  #5
Old 11-30-2010, 01:07 PM
Default
No way I could stretch out 32 feet worth of antenna inside my apt. I suppose I can string it from my kitchen, through my living room and then my bedroom but that's a bit much.. Haha.
  #6
Old 11-30-2010, 02:24 PM
TonyV225's Avatar
Default
I was referring mainly to the BS-1 LMAO!! I run one of those BS-1 when its storming out Ive made DX contacts with 20 watts pep with one of these BS-1 the ends are 9 foot long. I have it run along a laundry line on our inclosed porch.
I put the other bigger ham one up as a reference or to list the other options they make for dipoles.
__________________
  #7
Old 11-30-2010, 02:42 PM
Default
The ebay listing said 16.5 feet on each side! Haha.
How would this dipole compare to the bazooka? It's cheap enough that I should just try it out.
My problem is I'm on the 1st floor of a 6 unit building (2 units per floor). Right across the street are similar buildings so I don't have a clear shot anywhere. =/ I guess the only thing worse would be if I were in the unit at the back of the building or if I lived in a lead box.
Quote:
I put the other bigger ham one up as a reference to the other options they make for dipoles.
  #8
Old 11-30-2010, 04:36 PM
Default
ZuMBLe,
Honestly, A dipole of some sort is about the easiest antenna to make. I'd really consider doing that, making one.
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
your favorite CB myth , lies and legends . BOOTY MONSTER General CB Services Discussion 190 02-15-2012 07:54 PM
CB Radio - Antenna Basics: Part 1 Robb CB Antennas 14 01-26-2010 07:40 AM
Used CB Radio: How to Buy-Part 1 Robb General CB Services Discussion 5 11-30-2009 06:50 PM
Powered by vBulletin®
