Go Back   WorldwideDX Amateur Radio Forums > Amateur Radio Related > Amateur Radio Antennas
Amateur Callsign Lookup
Enter Callsign:
Jet Stream Fan Dipole JTFan8010bk
Reply
  #1
Old 01-06-2011, 08:52 PM
Junior Member
n8tnj is on a distinguished road
Default Jet Stream Fan Dipole JTFan8010bk
I have seen these dipole kits at various ham stores, for the price ($80.00) its not bad. All most the cost if you bought everything new. The only thing is I can't find any product review or anybody that has bought and used the antenna. Just wondering if anyone has tried this antenna, how it measures up to the elements. Or make my own.
  #2
Old 01-06-2011, 09:23 PM
Crotchety Old Bastard
W5LZ is on a distinguished road
Default
Five insulators, one stick of 1" PVC pipe and some wire from the hardware store. Why can't you do that for less than $80?
  #3
Old 01-06-2011, 09:25 PM
Moleculo has disabled reputation
Default
Disclaimer: I have not purchased the Jetstream Fan Dipole. However, there isn't anything magic about this simple antenna. The fan dipole is a good, basic multi-band dipole antenna. It's not going to do anything magical, but it does work as good as any dipole on the bands it is designed for. There is no magic in the design, so they're all going to work pretty much the same. You can either build your own or buy one that is pre-packaged like this Jetstream antenna. You could probably make your own for a little less, and you have to determine if the extra "pre-packaged" cost is worth it to you. If what you are looking for is an antenna like this, the Jetstream isn't any better or worse than any others.
  #4
Old 01-07-2011, 07:36 AM
Junior Member
Default
Well if you had to buy everything new, it would be around that price. Check the price of copper wire. Plus a balun, but any who. I was wondering about Jet Stream products themselves, never seen or heard or read of anybody using this dipole kit.
  #5
Old 01-07-2011, 12:39 PM
Default
Forget the balun, use a choke.
  #6
Old 01-07-2011, 01:50 PM
wavrider is on a distinguished road
Default
Quote:
Ugly choke cost? Time to roll it and a spacer, old 2 liter coke bottle, or some pvc pipe 4 inch. Cost of the coax.
PVC spreaders for the fan, maybe a few $ for one 10 foot stick, use the rest of what is left over for the insulators at the end of the antenna to tie the ropes to.
Price of wire? I find 100 foot extension cords at flea markets and yard sales for just a few $. That is three pieces of 100 foot stranded wire after the outside insulation is removed. Leave the individual wire insulation on each wire for weather protection.
I would say for less than $10 to $20 a 20,40,80 meter fan dipole can be built.
You also get 15 meters with the third harmonic off of the 40 meter band.
Three wires ( six if you count each side of the dipole) 4 bands, no tuner required. Does not get any better than that.
Antennas can be built better than any one purchased.
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Fan dipole wavrider Amateur Radio Antennas 18 05-10-2010 06:52 PM
Simple Desktop Cooling Fan Addition For Exports Wire Weasel Meters, Mics & Other Accessories 3 05-27-2009 05:07 AM
Need help with a Dipole. kf6wtc CB Antennas 0 01-31-2005 05:17 AM
Powered by vBulletin®
