Go Back   WorldwideDX Amateur Radio Forums > Amateur Radio Related > Amateur Radio Antennas
Amateur Callsign Lookup
Enter Callsign:
cooling oil for dummy load
Reply
  #1
Old 01-17-2011, 12:27 AM
towerdog's Avatar
one-niner-seven
towerdog is on a distinguished road
Default cooling oil for dummy load
What oil can be used. I would assume any oil would work so long as it is non conductive but I have yet to test any oil for conductivity.
  #2
Old 01-17-2011, 12:44 AM
Senior Member
Shockwave will become famous soon enough
Default
Quote:
Mineral oil will work in a pinch but it offers less heat dissipation then transformer oil. I believe you can purchase a gallon of "dummy load oil" on eBay for a reasonable price. Do not use any standard oil. Even if it shows low conductivity at DC with your ohm meter, it can respond much differently with RF. They typically have other additives in them that can cause problems.
  #3
Old 01-17-2011, 07:41 AM
359's Avatar
359 359 is offline
Senior Member
359 is on a distinguished road
Default
Quote:
How could a guy tell if he was sold transformer oil instead of peanut oil? Just curious.
  #4
Old 01-17-2011, 08:00 AM
EDUK8TR's Avatar
EDUK8TR is on a distinguished road
Default
Of course you can get the Mineral Oil at most local pharmacies. I was able to get some transformer oil for free. My electric company has a maintenance hub nearby. I simply went and asked for a gallon from the supervisor. After I explained what I wanted it for he simply had me write out and sign a note of the oils intended use. He then asked for and made a copy of my license and then had one of his crew hook me up with a gallon of the oil. It never hurts to ask.
__________________
"To be is to do"-Socrates;
"To do is to be"-Sartre;
"Do Be Do Be Do"-Sinatra;
WV4L,CDX-787,AK2787
Mobile/Base
Icom70000/Kenwood TS-2000 w/LDG AT-1000ProII
Stock mic or W2ENY headset on VOX/D104 w/Heil HC-5 or W2ENY headset on VOX
Tarheel 200A-HP w/N2VZ Turbo Tuner,Larson NMO 2/70B/TX-472 tower w/ 80M Horizontal Delta Loop, 20-6M K4KIO Hex beam, Gulf Alpha Dual Band Cross Polarity 7X7El. 2M:10 El.v70 CM beam, Arrow 146-440GP
Ameritron AL80A
  #5
Old 01-17-2011, 08:12 AM
359's Avatar
359 359 is offline
Senior Member
Default
I'll have to hit my FIL up, he retired from the local power company here.
  #6
Old 01-17-2011, 09:37 AM
Captain Kilowatt's Avatar
Professional Amateur
Captain Kilowatt is on a distinguished road
Default
I have used heavy mineral oil with no problems in a home made gallon sized dummy load while running an AL-80 into it. Regular cooking oils are not recommended at all and do NOT use any type of lubricating oil such as motor oil. Silicone load oil is the best to use if you can find it. Not sure what the stuff is that the power companies use, it may be silicone based.
__________________
Marriage is like a deck of cards. In the beginning all you need is two hearts and a diamond. By the end you wish you had a club and a spade.
  #7
Old 01-17-2011, 10:17 AM
Senior Member
Default
Quote:
You could try frying some peanuts in it and see how they taste.
  #8
Old 01-17-2011, 10:39 AM
King of NY
linearone is an unknown quantity at this point
Default
Quote:
What about the pure silicone brake fluid available now? Think that would work? Like DOT-5
__________________
Bomb Diggity!
_____________________________________
Quote Bob85: "peoples' personal non factual opinions mean nothing to me period, BS is 10 cents a gallon anywhere you look for it"
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
700 watt homebrew Dummy Load Radio Tech Home Brew 20 06-20-2010 09:57 PM
FEMA National Update: Thursday, June 3, 2010 FEMA FEMA Declarations and National Updates 0 06-03-2010 03:11 PM
Puzzling SWR/Dummy load issue Moleculo General Ham Radio Discussion 14 01-28-2009 02:47 PM
POWER LOSS AT VARIOUS SWR READINGS AND RESIDUAL POWER Unit 194 CB Band and CB Radios 15 11-24-2006 12:50 AM
Powered by vBulletin®
