Go Back   WorldwideDX Amateur Radio Forums > Amateur Radio Related > Amateur Radio Modifications
Amateur Callsign Lookup
Enter Callsign:
AOR AR-2002, Smoother and faster tuning
Reply
  #1
Old 06-08-2011, 06:54 AM
AudioShockwav's Avatar
Extraterrestrial Admin
AudioShockwav has disabled reputation
Default AOR AR-2002, Smoother and faster tuning
Anyone who owns an AR-2002 knows how frustrating the tuning knob is. Its hard-detented with loud "clicks" - you go nowhere fast. Luckily there's an easy fix that gives smoother, faster and quiet tuning. It only involves replacing the AR-2002's shaft encoder with that from another AOR receiver.
The AOR AR-3000A has a smooth-turning, high resolution shaft encoder. This successfully replaces the AR-2002's clunky & loud encoder. The best news is that AR-3000A shaft encoders are readily available, cheap, from a gentleman in California, Richard Robinson, K4EIH/6, jazz101@san.rr.com.
The wire colors are different between the 2 encoders, so just be sure to match them as follows.
(AR-2002) White - (AR-3000A) Red
(AR-2002) Blue - (AR-3000A) Black
(AR-2002) Black - (AR-300A) Brown
I performed this substitution without soldering. I also replaced the small tuning knob itself with a larger one from a Ray Jefferson radio. Any larger knob with a ¼" fitting will work.
__________________
Radio-active
NASA/SOHO
there is no dark side in the moon, really. As a matter of fact it's all dark
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
