Go Back   WorldwideDX Amateur Radio Forums > Amateur Radio Related > Amateur Radio Modifications
Amateur Callsign Lookup
Enter Callsign:
Wouxun KG-UVD1P Software Mod
Like Tree4Likes
Reply
  #161
Old 01-29-2012, 08:31 PM
Junior Member
TSellers is on a distinguished road
Default
I could be wrong but I seem to recall there was a MOD that you could do to some Yaesu radios that would open up a wide receive range well beyond what you could transmit on, so I suspect that is what might be expected here.
However from what I read, I thought that this software just opens up the band that the radio is capable of so it can transmit out of the HAM band to the limits allowed by that model of Radio. So for example if you have a 420-520 that's all you'd get. I also vaguely recall that you can open up the radio and tune it by shifting the band if you have a scope, but others here would know more about that than I would.
In Canada the KG-UVD1 managed to get DOC Type Approval, so it seems that many of the ones that are being sold there are already open for transmit on the bands they are rated for so this software may not be required. I'm not sure about the demographics behind the HAM versions, are they mainly sold in the USA, or are they also being sold elsewhere?
  #162
Old 02-05-2012, 09:46 AM
Junior Member
rikgrimaby is on a distinguished road
Default
hji all am noew to radio and having trouble with what numbers to put in and where..
can any one help ?
thanks
  #163
Old 03-04-2012, 10:06 AM
Junior Member
Yukikaze is on a distinguished road
Default
Quote:
Originally Posted by remote1 View Post
Yukikaze,
Just be aware that transmitting on police and fire freqs can bring trouble if your heard by them. Note that you could be on an input freq and not hear them but your still interfering with them.
It is safer to stay in the legal ham bands and just listen to the rest.
In some areas the 155.475 is still for active police and fire.
Just a thought...
Hi Remote.
Yes, you are correct.
One should be very carefull on transmitting outside the ham bands.
Where i live the 155.475 is mostly used by hunters, timber lorries, forest workers etc.
  #164
Old 03-13-2012, 03:43 AM
Junior Member
VK4ZDB is on a distinguished road
Default Frequency range probably limited by VCO
Radios usually consist of two main blocks, a microprocessor and an RF deck. You can use software to change the frequency range that the processor will display. It is usual for the VCO in the RF deck to be aligned to work over a set frequency range, and possiblly a bit outside the advertised range. So even though the micro is displaying a frequency the VCO ,and therefore the radio , will not work unless it is aligned for that frequency. VCO alignment was done in the factory and may involve changing a capacitor or software to change the VCO parameters, or most likely both. I have not been able to find a VCO alignment procedure . Dont expect the radio to work outside the advertised bands unless you can realign the VCO.
  #165
Old 03-27-2012, 08:32 AM
Junior Member
trailboss99 is on a distinguished road
Default
Hey guys, I'm having issues getting a driver to work with the radio and cable. Could someone be so kind as to take a looky and see what driver windows is using please? I'm on Vista. Thanks.
Col.
  #166
Old 03-27-2012, 11:29 PM
Moleculo has disabled reputation
Default
Quote:
Col.
Mine is the Prolific version 3.2.0.0 dated 7/31/2007
  #167
Old 03-28-2012, 01:57 AM
Junior Member
Default
And that one did the trick! Thanks mate, now I can go back to the fun of deciphering the Wouxun manual
I must say that for the money these little jiggers are amazing. One hell of a lot of radio for very little investment. It makes you wonder about the cost of the SRP-9100s that these will be replacing in a lot of cases around here. I bet they don't cost all that much more to make.
  #168
Old 06-17-2012, 08:02 AM
Junior Member
Rick345 is on a distinguished road
Default
I opened up the band limits on my Wouxun with no problems. However, I was wondering is there a way to program the channels/frequencies so the unit will not transmit on a channel?
For example I have the local WX freq. 162.550 mHz programmed into the radio and I don't want to say sit on the HT and irreverently transmit on 162.550 and have the FBI come knocking on my door a few days later.
Reply
Bookmarks
Tags
wouxun kg-uvd1p
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
NPC RC modification mod Happy_Hamer General CB Services Discussion 21 05-24-2012 05:50 AM
Wouxun KG-UVD1P Review Moleculo Product Reviews 93 08-29-2011 05:15 PM
RT Systems Software for Yaesu VX-8r Review Moleculo HandiTalkies 15 06-20-2010 05:30 PM
VX-8R MARS/CAP Mod question sapper326 HandiTalkies 13 01-11-2010 05:52 PM
TR-696FD-1 Variable Power Mod? Where?? Robb General CB Services Discussion 0 03-04-2009 07:52 PM
Powered by vBulletin®
