Quote:
Originally Posted by K4WHE Can someone please post up a link how to get the program to a .exe extension? |
Right click on the file. You will get a list of options.
Near to the bottom is "rename", left-click on this one.
The file name will now become active, with the name highlighted in blue(usually blue..).
The file extension, the .ex_ bit will not be highlighted.
Left-click your mouse at the end of the file name and you'll get a vertical cursor.
All you need to do now is delete the _ (underscore) bit and replace it with an 'e'.
Press return (or enter, depending on what you call the key).
You will get a prompt asking if you are sure you want to modify the filename as it may make the program unstable; left-click yes or OK (The affirmative option).
Bob's your uncle...
