Go Back   WorldwideDX Amateur Radio Forums > Amateur Radio Related > Amateur Radio Modifications
Amateur Callsign Lookup
Enter Callsign:
Wouxun KG-UVD1P Software Mod
Like Tree6Likes
Reply
  #25
Old 08-22-2010, 07:01 AM
Junior Member
K9OJ is on a distinguished road
Default
I just received my KG-U1P and it's a J08 serial number. I set the receive and transmit limits to 350-520 using the updated unlock program attached to the first post of this thread. I have confirmed with my scanner that it will actually transmit from 420-520MHz (I used low power inside a Faraday cage ).
The receive range is the same, 420-520MHz. I ran the scan function from 350 up with the squelch set very low and it picked up nothing until it hit 420 and immediately stopped scanning when it picked up stray noise.
The Serial Number sticker under the battery lists the radio's freq range from 136.000-174.995 & 420.000 - 519.995.
What a cool little radio. I can see why this thread has such a high view count. It's too bad the "vfo" function is such a pain--"Menu" "21" "Menu" select "Freq" or "Name," "Menu."
I got mine in three days from Ed at wouxun.us for $107 + shipping.
So far I'm very impressed.
K9OJ
  #26
Old 08-28-2010, 08:40 PM
Junior Member
skompier is on a distinguished road
Default
Quote:
Originally Posted by purplehaze View Post
Will it work with linux based operating systems?
FYI...
I used version 1KG-xxx-unlock.exe with WINE in Ubuntu 10.04 and it worked perfectly.
  #27
Old 09-01-2010, 10:29 AM
Junior Member
benering is on a distinguished road
Default
Does anyone know the upper and lower limits for Tx/Rx for this device? I just purchased a KG-UVD1P with a serial number starting with J08. I can successfully program the device with a range of 30-300 Tx/Rx for VHF and 350-520 Tx/Rx for UHF. I then tried to transmit / receive at 46.100 but could not. I am a firefighter, and am checking with one of our radios. Is it limited by the antenna, or is it an internal circuitry issue?
  #28
Old 09-03-2010, 05:26 AM
Junior Member
mr.sneezy is on a distinguished road
Default
benering, are you 'sure' it's actually working on the extended frequencies at all ?
Mine works fine on the display, but in reality receives nothing and sends nothing when 'out of band' by so much as a kHz. That was with the original FW posted. The newer one does not even read the original bands from the radio properly now. (hoping there will be an update for J07/J08 FW eventually)
  #29
Old 09-03-2010, 11:39 AM
Junior Member
Default
No. Not sure. Either update let me change the display so that I could enter a frequency that was above/below the original limits, but tx/rx on those frequencies would not happen, so I guess I am in the same boat you are!
Thanks for the response!
  #30
Old 09-04-2010, 01:13 AM
Senior Member
Qwazyone is on a distinguished road
Default
Quote:
According to the original post the limits are:
The allowed frequency range variations for the KG-UVD1P are:
2m/440 version
144-148 & 420-450 (TX)
136-174 & 350-470 (RX/TX)
136-174 & 400-480 (RX/TX)
136-174 & 420-520 (RX/TX)
136-174 & 400-470 (RX/TX)
144-146 & 430-440 (RX/TX)
2m/220 version
136-174 & 245-250 (RX/TX)
136-174 & 216-280 (RX/TX)
136-174 & 225-226 (RX/TX)
  #31
Old 09-09-2010, 01:59 PM
gc505 is on a distinguished road
Default
I've attached an updated version of the 1KG-xxx-unlock.exe file. It does the same thing as the one previously posted by Moleculo but this one has been translated to English:
73, aa9az
__________________
  #32
Old 09-24-2010, 11:41 AM
Junior Member
Don604 is on a distinguished road
Default
One thing I like about this program is the ability to actually "restrict" frequencies. While many may want to go out of band, I want to ensure that no one grabbing my radio can do that (at least on transmit).
For me, I found that setting 144-147 and 430-449 was more than enough to ensure no one could transmit out of band, while leaving the receive function totally open. When using 147 it actually gives access right up to 147.999, and likewise for UHF.
Reply
Bookmarks
Tags
wouxun kg-uvd1p
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
NPC RC modification mod Happy_Hamer General CB Services Discussion 21 05-24-2012 05:50 AM
Wouxun KG-UVD1P Review Moleculo Product Reviews 93 08-29-2011 05:15 PM
RT Systems Software for Yaesu VX-8r Review Moleculo HandiTalkies 15 06-20-2010 05:30 PM
VX-8R MARS/CAP Mod question sapper326 HandiTalkies 13 01-11-2010 05:52 PM
TR-696FD-1 Variable Power Mod? Where?? Robb General CB Services Discussion 0 03-04-2009 07:52 PM
Powered by vBulletin®
